73-87 Chevy _ GMC Trucks => Electrical => Topic started by: rcollamore on May 26, 2016, 12:14:19 am
Title: 1987 Chevy Suburban Headlight Wiring Harness
Post by: rcollamore on May 26, 2016, 12:14:19 am
I am looking for the name of the piece that is at the end of the headlight wiring harness that connects to the fuse box on the firewall.
I just that part to get my headlight working because I am missing mine and I am unable to connect the headlight wiring up. And I don't want to buy the whole head light wiring harness seems like a waste if I am able to find that part.
Sent from my VK810 4G using Tapatalk
Title: Re: 1987 Chevy Suburban Headlight Wiring Harness
Post by: LTZ C20 on May 26, 2016, 01:56:20 am
It's called the bulkhead connector.
Post by: hatzie on May 27, 2016, 04:46:38 am
The bulkhead plug,  on the engine compartment side, is actually several plugs that fit together.  Most of the bulkhead connector pieces are discontinued.  The discontinued 1987 forward lamp harness connector is Delphi Part # 8917233.  It takes Packard 56 female terminals.  You can buy the terminals but the connector is only available if you want to buy an entire production run of several thousand or find one used.
You can find a PDF of the 1987 GM Light Truck full line Wiring Manual in one of the folders linked in my signature.  The 1987 squarebody is an RV series.  The RV series forward lamp harness is on page 167 & 168.
Post by: rcollamore on May 27, 2016, 09:16:54 pm
Thank you for help with that lol ya I tried looking for one after I saw your answer lol I think I am going to see if I have any luck at junk yard.
