73-87 Chevy _ GMC Trucks => Electrical => Topic started by: Allblackcars on May 29, 2016, 06:52:13 am
Title: Blowing Fuses....Help!
Post by: Allblackcars on May 29, 2016, 06:52:13 am
When I hit my brakes I hear a pop from the fuse panel area. I have tail lights but no brake lights.
This issue continued for a couple days and then I noticed my right turn signal dash light not blinking.
I started tampering with the turn signal stalk and then it will blow the turn signal fuses when I put right turn signal on, only....
So the brake light fuse was the first issue
Right turn signal became the second...Not sure if it's related
1986 Silverado
Title: Re: Blowing Fuses....Help!
Post by: VileZambonie on May 29, 2016, 08:37:13 am
Go to the right rear tail light and remove inspect the bulb, socket and related wiring.
Post by: Allblackcars on May 29, 2016, 11:01:42 am
I pulled the lens and then the assembly... Didn't see anything noticeable. Cleaned spade that clamps onto assembly... Wires dusty but nothing frayed...
Post by: Allblackcars on June 16, 2016, 10:23:40 pm
 Update: dead short where wiring got onto exhaust after c- notch in rear....All problems resolved
Sent from my iPad using Tapatalk
