73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: jg1977c20 on June 11, 2016, 01:06:50 am
Title: does this ever happen ??
Post by: jg1977c20 on June 11, 2016, 01:06:50 am
so i purchased a set of upper control arms from moog the heavy duty ones complete with new pivot shaft and problem solver ball joint - they have been awesome - but the other day i was looking under the hood and noticed the threads on the passenger side showing , a closer look proved that the end nut that screws into the end of the control arm was unscrewed a good 1/2 inch or so - anyone ever have these things loosen off by themselves ?  1977 c20   these are the shafts without the rubber bushings
Title: Re: does this ever happen ??
Post by: VileZambonie on June 11, 2016, 01:47:34 pm
sounds like the nuts weren't properly secured after the alignment.
Post by: jg1977c20 on June 11, 2016, 03:36:27 pm
i think your referring to the nuts that hold the control arm and shims to the frame -  i'm talking about the large 1 3/8 " nut that screws onto the end of the pivot shaft right up to the large holes in the arm - theyve been in there for a year and then suddenly the front passenger one was near fully unscrewed
