73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: bcstingray on July 23, 2016, 02:02:00 pm
I bought this front sway bar for my 73 1/2 ton. It didn't have one on it when I bought it. This one came off an 87 ton dually. Will it work on my 1/2 ton or would it be too much?
(http://i1275.photobucket.com/albums/y449/bcstingray/sway%20bar_zpsh2if1net.jpg) (http://s1275.photobucket.com/user/bcstingray/media/sway%20bar_zpsh2if1net.jpg.html)
As long as you have the holes in your lower control arms I believe it should fit. Depending on how worn it is and how worn or sagging your current suspension is, you may gain a little bit of lift if the sway bar hasn't been stressed in its previous life.
Did you get the brackets that are riveted to the frame?
Pictured
I do have the mounting holes in the lower control arms. I didn't get those brackets. One was broke and the other was still riveted. The guy didn't want to take time to take the good one off. Will I need them for a 73?
yes you will need them. I use an air chisel to remove and bolt them back on with grade 8 bolts
I'll have to buy a set then.
Wrecking yard, should be able to find more than just 2.
I just took a set off my 85. If they'll fit you can have them. Text me 216-816-5805 Ben
