73-87 Chevy _ GMC Trucks => Suburbans => Topic started by: paintinx on August 18, 2016, 12:38:30 am
Title: air filter sub79
Post by: paintinx on August 18, 2016, 12:38:30 am
good morning
i drive a 1979 big block suburban with th400 and have a special question
regarding my air filter.
look at the photo i have uploaded ...
this type of air filter is installed since i bought the car a few weeks ago.
it has the size of 290mm mal 136mm / 11,4inch by 5,3inch
my seller told me that his offer for a new air filter is
306,324mm by 88,646mm / 12inch by 3,4inch.
which one would be the better for my light truck?
thx in advance, stephan
Title: Re: air filter sub79
Post by: Irish_Alley on August 18, 2016, 03:19:39 pm
i dont think you will notice a difference. the smaller filter looks better (cleaner) imo but performance i doubt you will see anything. whatever you do keep that air horn with the heat riser hooked up. in the colder months you may see a performance problem without it
Post by: LTZ C20 on August 18, 2016, 10:28:50 pm
The "air horn" Irish mentioned, (proper name- air filter housing), keeping it for cold weather drivability is pointless with a filter that large inside it. That large of a filter basically bypasses the heat riser system completely by drawing in all the cold air above the filter.
The only way, the heat riser system is affective is if the factory size filter and the factory air filter housing cover are both installed. This way, cold air is bypassed and warm air is drawn in until the engine has reached sufficient temperature to open the cold air valve and stop drawing warm air from the exhaust manifold.
The best thing to do is just put the factory size filter and the cover on. A stock engine will not benefit from a larger filter in any noticeable way.
Title: THX
Post by: paintinx on August 19, 2016, 02:28:37 am
Post by: Jason S on August 19, 2016, 09:44:13 am
From the photo, it looks like the air cleaner assembly is off an 1980's truck.
Do you have the correct cover for your air cleaner?  It should look something like in the photo below.
(https://lh4.googleusercontent.com/-RyUVM3OQ4_k/T4Yrq-6WRiI/AAAAAAAAATg/m21vwYaSyuc/s400/DSC01793.JPG)
If you have the correct cover, then I would just replace the filter with one identical to what you have. We had an '86 GMC 1500 Suburban with a 350 that had the same air cleaner from the factory.
Post by: LTZ C20 on August 19, 2016, 10:49:46 am
Jason is on the right path here with the air cleaner cover, he is right about it looking like possibly an 80's air filter housing. The actual correct air filter housing for 1979 is this.
(http://uploads.tapatalk-cdn.com/20160819/5f0fbbe3af445d2a1b64613f3a3bda83.jpg)
(http://uploads.tapatalk-cdn.com/20160819/3c46f783366f8aab93b8338a26ef8e5c.jpg)
(http://uploads.tapatalk-cdn.com/20160819/114b3b531478f79a6326a245a994d0f7.jpg)
Post by: roundhouse on August 20, 2016, 10:51:06 am
I always installed a taller filter or flipped the lid to hear the four barrel
Nothing in this world is a sweeter sound than a four barrel winding up to the redline
And yes , we prefer to be called Appalachian Americans
Hillbilly is an offensive  micro aggression term
Title: i got THIS black one
Post by: paintinx on August 27, 2016, 09:47:34 am
hej
these days I ordered the black one, but it looks like "to small".
the red one looks /imho/ to big ...
and what is the part inside the air filter (the "gold"colored thing)
I also attached a photo from my closed filter.
I miss the thing in front of the "sugtion"cjkdhckskc - sry, dunno the word in english.
is it important to have it???
Stef
Post by: LTZ C20 on August 27, 2016, 10:38:38 am
The little gold thing in your second picture is a Thermostatic temperature switch. At certain temperatures it either opens or closes to either provide or cut off vacuum supply.
The thing in question in your first picture is called the snorkel or air intake duct. It provides a funnel for cold air to be pushed thru the grille into the engine. Not required but the entire system works better when you have it, especially in cold weather.
Post by: paintinx on August 27, 2016, 11:50:55 am
THANK YOU LTZ20!
great. Stephan
Post by: LTZ C20 on August 27, 2016, 09:17:58 pm
Your very welcome.
Title: question regarding "fit the filter"
Post by: paintinx on August 29, 2016, 03:19:28 pm
hej ...
i have a question again regarding the air filter I bought.
please, look at the photos i uploaded a few days ago.
is the new one (black) the right thing or should I better use
the older one (the red one)?
in my opinion, the black one is to small.
air could find a way above the filter into the system, or?
best, stef
Post by: Irish_Alley on August 29, 2016, 04:21:41 pm
if your filter doesnt touch top and bottom the air will just bypass it. take your old one in and match it up if you have to
Title: thx, now ...
Post by: paintinx on September 02, 2016, 11:12:33 pm
I have only one question more regarding the air filter parts.
how is the rubber/snorkel at the end of the air filter housing called and where could i get it?
u can see that i am missing the "gummiteil" :) on my car.
thx, stef
Post by: LTZ C20 on September 03, 2016, 01:49:34 am
Not sure which part your referring to. The snorkel if that's what you mean, is just that, the snorkel OR air intake duct.
Title: good morning
Post by: paintinx on September 03, 2016, 02:38:53 am
and thx for the reply.
i sm actually looking for the part with the arrow on my new photo.
but i have found an other way - look to the other photo - i asume
it is also from the forum here.
my other question is - both photos (cars) have an air filter
which is smaller then my air filter (look to the photo in thread begin)
maybe the reason is a other type of machine (454)
best, stef
Post by: LTZ C20 on September 04, 2016, 11:24:18 am
Your picture with the arrow is called the snorkel or air intake duct. The other solution picture you posted could work too. Getting the factory snorkel shouldn't be hard tho, the used ones are cheap and some companies sell new ones that are also cheap.
Also, your other solution photo has the correct air filter housing for your 79 suburban. The one you have now with the larger filter is from an 1980s model truck.
Title: thx again ...
Post by: paintinx on September 04, 2016, 03:29:58 pm
and sry, it seems like a stupid question
but I currently have to find out a lot regarding my sub79.
so i hadn`t enough space in my brain
to get it by myself ^^
1980 air filter ... so easy.
thx, stef :)
Post by: LTZ C20 on September 04, 2016, 03:35:37 pm
Your welcome.
