73-87 Chevy _ GMC Trucks => Electrical => Topic started by: tc197 on September 17, 2016, 02:12:57 pm
Title: I'm creating more problems than I'm fixing.
Post by: tc197 on September 17, 2016, 02:12:57 pm
87 GMC V2500 TBI 5.7 SM465 NP208
I'm beyond frustrated with my truck right now. I've blown more hours than I want to count trying to fix a problem that didn't exist until I caused it.
Everything started a month ago. My trans was leaking so I decided to replace it. Truck ran great otherwise, no issues, just didn't want to leave puddles everywhere I went. Dropped the trans and tcase, replaced the pilot bearing, clutch, flywheel, throwout bearing, and swapped the new trans in. Took me an entire labor day weekend by myself as I've never done anything like this before. Got everything in and went to roll the truck off the ramps in my driveway and I didn't have brakes. No big deal, quickly saw I had crushed a brake vacuum line, a few hours later I had brakes again.
Everything was going fantastic. I had actually swapped the trans in successfully. It shifted and drove great, it started right up, life was good. Before going to leave for the night I decided to do a walk around and make sure I hadn't forgotten anything. Truck was running, I pulled the headlight switch on and bam - instant dead. Truck lost all power to everything. I shut the headlight off, tried to restart the truck, and it fired up and immediately died. From here on out I've had nothing but problems.
First I checked all my fuses near the e-brake, nothing was blown.
Checked the fusible links after reading about them here, saw one was cracked open so i replaced it, still nothing.
Pulled all the grounds I could find, resanded the contact points, and rebolted them all down. Still nothing.
Replaced the headlight switch. Nothing.
I had a spare steering column because mine was busted up and decided I'll just swap that in and see if that helps anything. Got everything apart, had rust holes breaking open in the firewall because it had clearly never been taken out before, got the new column in, now I can't even get it to crank.
Played around for a few hours trying to see if I did something wrong, gave up, and put the old steering column back in. Cranks again - still no start - headlight kills all.
Saw I hadn't cleaned the ground from the alternator to the alternator bracket so I pulled it and cleaned it. Went to start the truck and now I don't even get a click. Battery reads 12.7 on the charger with no load, I have power to the starter. I have power to the alternator. I'm at a complete loss.
Some how in cleaning that ground I moved backwards in progress and now I can't even get my truck to crank. The wiring harness has been hacked to shoot, I have disconnected plugs all over (all were disconnected pre-trans swap as well by previous owner) and I don't know what to do or where to start. When I turn the key I get blinkers, heat/ac blower, hazards, wipers but nothing else. I don't here the fuel pump click, I don't get radio, when I try to start it I don't get anything at all. Headlights still don't work. All I wanted to do was stop my transmission from leaking and now I have a truck in pieces that I can't drive and I can't figure out what the problem(s) are. Any advice?
Title: Re: I'm creating more problems than I'm fixing.
Post by: hatzie on September 17, 2016, 05:44:46 pm
Something blew out that fusible link.
I didn't see mention of finding the culprit.  Find the reason the fusible link blew out before you go any further.
Since this happened after a transmission swap I'd check the 10ga wires down the bellhousing to the starter and make sure you didn't pinch them.
Post by: tc197 on September 18, 2016, 08:39:06 pm
Thank you I'll check into that. Also the fusible link still had continuity across it, just the plastic box itself was cracked open. Not sure if that meant the link was toast or not so I replaced it anyways.
Post by: 80Chevy4x4 on September 18, 2016, 08:43:25 pm
Welcome to our wonderful world of Truck Modifications......LOL    you are passing the test  :)
Post by: VileZambonie on September 19, 2016, 08:48:13 am
I agree with Hatzie, you probably pinched a wire. Check carefully between the back of the engine and the trans. Repair and then replace your fusible links.
Post by: tc197 on September 19, 2016, 09:35:46 pm
Unfortunately I'm away from the truck during the week so I won't get a chance to try this stuff until the weekend. I was reading another thread that mentioned making sure the alternator hadn't seized so I'll check that too.
My plan so far:
1. Make sure alternator isn't frozen
2. Pull starter and check fusible link/for pinched wires (I could see/feel the wires running down to the starter and didn't notice any still pinched but it's possible something got squished and didn't stay squished)
3. I was reading about a ground that's supposed go to the back of the motor? I definitely haven't found that ground yet - so far I've cleaned up the battery to the frame, the battery to the front sheet metal, the alternator bracket, the left headlight to the front sheet metal, and I have continuity between all of these grounds back to the negative terminal of the battery.
The thing that started all of this (back when it still cranked over) was pulling the headlight switch and I've yet to solve that problem. I appreciate the help guys!
Post by: tc197 on September 24, 2016, 06:25:15 pm
Update from today:
Started the day off by making sure the alternator spins, it does and is nice and tight so all seems good there. Next I pulled the starter and jumped with my battery. Starter is good. From here I knew something between the steering column and starter was an issue. I checked the fusible links and all of the wires around the starter. The fusible link looked good and had continuity, all of the wiring looked good. Nothing was crushed, nothing was stuck in the bellhousing, etc. I checked all my fuses and as a last ditch effort ran to the parts store and bought a new ignition switch. Installed the ignition switch and now it cranks over. Somehow in trying to fix my initial problem, I fried my ignition switch.
Now I'm back to the beginning. The truck cranks over but does not start. The blinkers, brake light, wipers, blower, all work fine. The headlights do not work and the check engine light is not coming on prior to trying to start it. I can visually see fuel spraying when it is cranking with the air filter removed. Everything started going downhill after swapping the transmission and then turning the headlights on. From this point forward the truck hasn't run the same. What am I missing that somehow links my headlights to the truck not starting/running properly?
Post by: 80Chevy4x4 on September 25, 2016, 08:16:50 am
I can't remember the exact way your engine compartment looks,but a quick thing to check is to make sure the distributor cap did not get cracked or has been kicked sideways a hair...i know a lot of problems when replacing a transmission is the distributor hit the back firewall when the engine was lowered.....this might help...check for spark.
Post by: tc197 on September 25, 2016, 12:00:22 pm
Thanks for the tip. I don't see any cracks and what makes all of this extremely confusing is that it will start and immediately die. I'm having trouble explaining what exactly is happening so let me try again.
Headlights don't work period.
Key on - no dash lights.
Crank for 2-3 seconds - check engine light appears -1 more second - truck starts.
Truck immediately dies - if I give it a lot of gas the truck will stay running - as soon as i stop giving it gas truck dies - loud squeal when giving it gas from belts
The reason I'm so confused is I can see fuel spraying and it will start so I must have some spark and fuel. I would figure if my fuel or spark was off a little it would still run but just real crappy. Plus, this all happened the 1 time I pulled the headlight switch so somehow that problem is related.
Post by: VileZambonie on September 26, 2016, 04:59:01 pm
Recheck your fusible links. Give a good tug on them to make sure they aren't fragile. (disconnect battery when you do this)
Post by: tc197 on September 27, 2016, 09:58:32 pm
I've checked the fusible links many times now and I don't see any problems with them. One at the starter, one at the battery, one at the junction box on the firewall, and one at the alternator. As I am doing research on the site I see people saying that the junction box up by the firewall has multiple wires coming out of it and for me this is not the case. I only have 1 wire into the box and 1 wire out of the box with a fusible link on the wire leading in. Is this a problem?
Post by: VileZambonie on September 28, 2016, 06:18:49 pm
Either you missed something and need to re-recheck or you did not properly connect your grounds. Recheck the back of the pass cylinder head, my the T-stat housing and check your fuses at the fuse block.
Post by: tc197 on September 28, 2016, 06:37:50 pm
So I never pulled any of the grounds off but it could be possible that I broke the ground on the back of the passenger cylinder head when the motor was tilted back for the trans swap. When you say back of the cylinder is it something I should be able to see? I can feel 2 wires going to that general area but I can't actually see them due to the limited space. What is that ground going between? Is it the cylinder head to the firewall? Can I test that ground by just adding a new ground next to it to wherever it needs to go?
I appreciate the help. I've checked every fuse multiple times and none of them are blown.
Post by: VileZambonie on September 28, 2016, 06:53:22 pm
Check the bulkhead connector and all of your wiring connections. Push the fuse box toward the firewall and make sure it is tight. Run an auxiliary ground from the battery to the engine block then perform the tests again in the chart.
Post by: tc197 on September 28, 2016, 07:02:57 pm
I took the fuse box completely off already and made sure everything was clean and seated properly when I reinstalled it. I also do have continuity from the negative battery terminal to the block but I can run a second wire. Where did you find that chart? I need to find the A-1 chart because when I ignition on my check engine light does not come on. It only comes on once I start cranking the motor for about 3 seconds.
Post by: VileZambonie on October 04, 2016, 12:25:22 pm
If you have verified all of your connections and performed all of the other checks then swap out the ECM.
Post by: tc197 on October 09, 2016, 10:07:47 pm
Trucks driving me insane. Im not sure what I should be looking for. I have continuity everywhere that seems like I should. Tomorrow im going to run more ground wires around to see if it helps any. I just dont understand how it can start to run and then just die while at the same time my headlights dont work.
Post by: 1967KaiserM715 on October 10, 2016, 05:51:09 am
Having continuity is only half of it. Sometimes you can find a fault with continuity, but if you don't you need to go deeper. Example, on slow cranks sometimes the cables look fine, they have continuity, but corrosion can cause several strands of wire in the cable to become seperated and while this still shows continuity, you can't push the same electrical power through the cable. I have a feeling this is what happened with some of the links behind the engine-some wires got crushed and even though they show continuity, they can't allow enough energy through to power anything
Post by: tc197 on October 10, 2016, 01:25:42 pm
That makes sense, but what doesnt make sense to me is how it will start if I just crank it for a few seconds but then it will die. Isnt the highest draw on the electrical system while it is cranking? And why does my check engine light come on after it cranks for a few seconds but not when i ignition on? Theres something wrong with ny headlights because even with the ignition off i cant get them to turn on. I think this is my problem but im having trouble tracing it back. My blinkers work, my brake lights work, and my headight switch is new. My headlights dont work, my dimmer switch doesnt work, my high beams dont work, and I dont think my horn works but i have the steering wheel off right now.
Post by: 80Chevy4x4 on October 10, 2016, 03:58:09 pm
Time to get a wiring diagram and trace each wire. I would do that instead of fishing....it could be many things.
Post by: tc197 on October 10, 2016, 05:06:06 pm
Finally made some legitimate progress. Found the A1 Chart for no SES light when ignition on here : http://forum.73-87chevytrucks.com/smforum/index.php?topic=25461.msg212295#msg212295
Wasn't sure if I would consider my engine starting or not because it fires for only a second before dieing. Either way I followed both directions in the chart and did the tests.
For engine starts: I disconnected the ecm and probed ckt 419 with the test light at the fuse box. The SES light was NOT on. The solutions to this were centered around an SES light that is no good, however, I know my SES light is good because if I crank it for 3 seconds, the light will eventually come on.
For engine doesn't start: I disconnected the ecm and probed ckts 340 and 439 with test lights at the fuse box. The light was ON for ckt 439 (ecm fuse) and the light was OFF for ckt 340 (ecmb fuse)
Case 2 of "engine doesnt start" seems to be more applicable and has a problem with the ecmb fuse circuit. Looking at the wiring diagram in that same thread it seems that the two items are the fuel pump relay and the oil pressure switch. When I ignition on I hear the fuel pump kick on for 10-20 seconds (buzzing noise inside fuel tank) and then it shuts off. I'll have to look into what the causes of a bad relay are and the same for a bad oil pressure switch.
How this relates to my headlights I have no idea, but at least I feel like I have something to go off of right now.
Post by: 80Chevy4x4 on October 10, 2016, 07:42:04 pm
Yea that is a real good start.....the fuel pump runs off the oil switch...if you lose oil pressure the fuel pump will shut off....the fuel pump will always cycle until it reads no oil pressure....so you are on the right track...as far as the headlights.....have you checked the bulbs to make sure they are still good?   even after all the testing?  Bulbs can go at any time...hope this helps.
Post by: tc197 on October 10, 2016, 09:08:40 pm
Havent checked the bulbs recently but along with the headlights I lost my gauge backlight and that hasnt come back yet either. I suppose I could have blown a bunch of things at once but ill have to check.
As for the fuel pump situation, my oil gauge is pegged at max (was before my problems too) so i would assume that would be good for the fuel pump because it will always cycle. Another thing I tried was I found on here that the extra wire sticking out of my pump relay was a test plug. I ran a line from B+ to that connector to see if my pump would cycle and I got nothing (ecm was still disconnected if that matters). Would this mean my pump relay is no good?
Is there any connection between the ecmb circuit and the headlight circuit?
Thanks for the help guys, its been weeks on weeks now trying to fix this one stupid electrical problem. I havent even gotten to enjoy the truck after swapping the trans and its getting cold to keep riding my motorcycle. Hopefully this doesnt take too much longer
Post by: bd on October 10, 2016, 11:28:22 pm
Stop and regroup!  I concur with hatzie and VileZambonie.  Either a fusible link did its job or it is disconnected or severed.  Chances are that you either created a dead short that still exists or a transitory short that doesn't.  Whichever scenario occurred, it resulted in a zapped (or open) fusible link.  In a new unit of time re-inventory the fusible links.  Don't make ANY assumptions no matter how many times you have already looked at it.  Observe as though it's the first time through, using the 1987 Wiring Manual (http://www.73-87chevytrucks.com/techinfo/7387CKMans//Wiring/ST_350_87_1987_Chevrolet_GMC_Light_Truck_Wiring_Manual_Complete_11x17.pdf#page=163) for reference.  But be advised, the 1987 Wiring Manual requires patience to interpret correctly and understand.
Fusible links are generally about 6" long located at the "hot" end of the wiring they protect.  The circuit number of a fusible link may differ from the circuit number it protects.  Unless the wiring in your truck has been modified, there are two fusible links connecting to the starter 3/8" solenoid stud (Ckts 2E and 2I).  One of the links (Ckt 2I) routes through a red wire directly to the firewall bulkhead connector and into the cab (Ckt 2H); the other fusible link (Ckt 2E) connects through a red wire to the firewall junction block (Ckt 2G).  A redundant fusible link (Ckt 2F) exits the firewall junction block and runs through red wire, again to the firewall bulkhead connector and into the cab (Ckt 2C).  No fusible links connect to the battery or alternator.
Unfortunately, the 87 diagram is vague regarding the transition of Ckts 2H and 2C through the bulkhead connector.  I believe Ckt 2H becomes Ckt 2E and powers the ignition switch, which in turn powers the ECM-B fuse.  I also believe Ckt 2C splits into Ckts 2A and 2B; Ckt 2A powers the hazard flasher and small appliances requiring constant B+ and Ckt 2B powers the headlamps through the headlamp switch.  Perhaps hatzie or VileZambonie can help clarify circuit 2 transitions through the bulkhead.  Otherwise, you can verify the circuits yourself by observing how and where they connect.
Describe how you have been checking the fusible links.  Headlamps are a high-current circuit.  A fusible link can be partially melted and limit the current flow through a high-current circuit, but still measure continuity if checked with an ohmmeter or checked with a voltmeter when the circuit isn't loaded.  Have you been using a voltmeter, an ohmmeter, a test light, or __________ to check the fusible links?
Post by: tc197 on October 11, 2016, 12:44:28 am
I appreciate the extensive response bd. My truck is definitely wired wrong. I won't be able to get to it until this weekend but here is some info for now that I am 100% on.
What I have:
- 2 wires coming off b+, thick one to starter and thinner one to alternator. The thinner one has a fusible link immediately after the b+ terminal before the alternator.
- after the alternator I have a second fusible link on a red wire.
- on the same starter stud as the thick b+ cable from the battery, I have a third fusible link that is on a smaller red wire running up behind the motor.
- finally my firewall junction block has only 1 wire in and 1 wire out. I don't know which side is in and which side is out, but one side has a fourth fusible link on it.
For testing fusible links, Ive pulled on them, checked continuity with a dvm, and checked for 12ish volts with a dvm. The fourth fusible link (firewall junction) I replaced as the plastic housing was cracked. I did not load test them or use a test light on them.
ive replaced the headlight switch, ignition switch, ignition coil, plug wires, egr valve (before problems), and cleaned (sanded to shiny metal with a dremel) the grounds at the b- to frame, b- to radiator support, altenator bracket, drivers headlight to sheetmetal, passenger headlight to radiator support, ecm to back of cylinder head, and inside the dash the 6 prong connector which has 1 ground cable connected.i also checked continuity between various ground locations to the b- terminal.
The fan blower, turn signals, brake lights, and wipers all work.
The headlights, dash lights, high beams, radio (disconnected now), and I think horn (steering wheel is off) dont work.
When i turn the ignition on, my voltage gauge reads 12ish, my oil pressure is maxed, no dash lights come on, the fuel pump runs for like 15 seconds, and it will crank. If I crank it for about 3 seconds, the check engine light will come on, and shortly after the truck will start for a split second and die out. If throttle is applied in the split second its running it will run slightly longer.
Post by: bd on October 11, 2016, 01:38:25 pm
...For testing fusible links, Ive pulled on them, checked continuity with a dvm, and checked for 12ish volts with a dvm.  ...I did not load test them or use a test light on them.
With respect to any future diagnoses of power delivery to various components, unless it is specified in a diagnostic manual an ohmmeter is the wrong tool to use.  An ohmmeter can be used successfully to compare the measured resistance of a component to its engineered resistance when the engineered resistance is a published constant, but using an ohmmeter for general diagnosis of power problems can be very misleading - more so when high current flow is involved.  For instance, if a starter draws 150 amps at 12 volts, the starter motor has an effective resistance of only 0.08 Ohm.  A resistance in a battery cable of merely 1 Ohm (which is 10x the resistance of the starter motor) could effectively prevent the starter from cranking.  Only a laboratory grade meter can accurately measure resistance that low.  So the typical DVM would show excellent continuity on the cable, yet the engine wouldn't crank.
Well, fusible links are just high-current, slow-blow fuses.  Any damage to a link can impact its ability to transfer current effectively.  A damaged link that hasn't actually severed can check fine for continuity using an ohmmeter and yet not function when placed into service under load.
The best methods for checking fusible links are:  1) inspect for blistering and/or rupture of the link insulation and for evidence of heat caused stress, 2) give a tug to see if the link stretches like a rubber band or breaks, 3) measure voltage drop across the link while the link is in an operating circuit and under load, and 4) use an incandescent test light for a quick test while the link is in an operating circuit and under load.  In a nutshell, you should recheck all of the links.
Post pics of the fuse links connecting to the alternator and to the starter, as well as pics of the bulkhead connector from the engine compartment.  How many 12-gauge red wires enter the bulkhead connector from the engine compartment?  There should be two and both should measure B+.  Don't be confused by all the little things that don't function correctly at this time.  Some may resolve by reestablishing power into the cab through the bulkhead; others are unrelated and can be resolved later.  Did you ever check for power into the ignition switch and headlamp switch?  FYI - the headlamp highbeams/lowbeams are powered separately from the running lights and instrument lights.  There is a procedure posted in the Technical Pages of the forum regarding diagnosing dash lights that don't work.
More later after you post the pics.
Post by: tc197 on October 12, 2016, 11:28:07 pm
Thanks for all the help!
I won't have a chance to get pictures of the links until this weekend so instead what I've done is ordered 4' of fusible link and some terminal connectors. I'll make up new fusible links and just replace all of them to eliminate the errors I'm making in testing the old ones. Unfortunately it's looking like I'll only have friday night to get some work done on the truck this week so I'll replace all the links and take pictures, check on the red wires entering the bulkhead, and make sure those red wires have B+.
I think i was misunderstanding how the wiring was setup, I was assuming that since the motor cranked and fired that the fusible links with continuity would be a valid check. They had continuity, and they could support the draw necessary to crank the motor. What I am now understanding is that the fusible link coming off the starter and at the bulk head don't care about the cranking current, but rather come into play once the motor fires and power needs to reach the rest of the trucks components. This would make sense why the truck starts but immediately dies because the weak wires can't support the current load for more than just a quick start. Sorry that it took like 4 different people pointing this out for it to finally click with me.
If replacing these links does in fact work I guess the next question is what happened to cause them to fail to being with. I did a lot of work and did move the motor around when swapping the trans so it is possible they were just old links that I stretched/stressed and that was enough to blow them. I guess I'll find out when I go to start the truck up and if the new links blow then I know for sure I have an issue somewhere else.
It's a frustrating process but without all these set backs I wouldn't know nearly as much about my truck as I do now. Thanks again for all the help guys.
Post by: bd on October 13, 2016, 01:41:16 pm
Gauge choice of fusible wire is strictly dependent on the gauge size of the wiring being protected.  See How to make a Fusible Link (http://forum.73-87chevytrucks.com/smforum/index.php?topic=11972.msg45217#msg45217) for a description of the relationship.  The only fusible links with which you should be concerned at the moment are the three (two at the starter and one at the firewall junction block) that feed power into the cab through the firewall bulkhead connector.
Post by: tc197 on October 17, 2016, 11:19:40 am
Sounds good BD, thanks for the link. Wasn't able to get to the truck this weekend. Fusible link I ordered was delivered late so it's looking like later this week I'll have a chance to get some work done.
Post by: hatzie on October 18, 2016, 07:16:52 am
You can use the much easier to read and interperet 1988 RV manual as a loose reference crutch till you get up to speed on what GM did in the 1987 manual.  It's worth noting that the  1987 & 1988 manuals are "full line" manuals so the T400 CK models are in there along with G & P vans and ST trucks too.  You'll need to page to the RV series sections.
There are differences between 87 & 88 but the fusible links and primary circuit 2 wiring should be close if not the same.
Print the 1987 RV wiring manual pages you need and mark em up with hi-liter or colored pencil.  The original page size is 11x17.
If you have a local Fedex Office or access to a printer that will handle the original 11x17 Tabloid size pages, or even better these PDF files were scanned at a high enough DPI to print on 12x18 Arch B by scaling in the print dialog of Adobe Reader...
The wiring manuals list the wire gauge of the fusible links and each individual wire so there's no need to guess.  They also include jacket color and information on wiring jacket composition ex SXL, TXL, GXL...
In 1988...
The "thin" 1.0mm fusible link at the starter goes to the bulkhead plug and on to the ignition switch and fuse panel.  1.0mm = 16AWG
The "heavy" 2.0mm fusible link at the starter feeds the junction stud on the firewall.  2.0mm = 14AWG
 look at the 1987 power distribution pages to verify GM didn't change something.
Post by: tc197 on October 24, 2016, 02:13:43 pm
Thank you for the additional information! No updates yet, I haven't had a chance to get home to the truck. Without a doubt it will happen this weekend at the latest.
Post by: tc197 on October 29, 2016, 10:34:58 am
Finally got to my truck. Unfortunately replacing the fusible links did me no luck.
Post by: bd on October 29, 2016, 12:40:48 pm
... I'll ... take pictures, check on the red wires entering the bulkhead, and make sure those red wires have B+....
Have you had a chance to do this yet?
Post by: tc197 on October 29, 2016, 01:07:53 pm
Yes im in the process of that now. What is the best way to check the b+ on those red wires? I just found out I have no power at my ecmb fuse with ignition on. On the engine side of the firewall where the red wires enter the cab there is a bunch of old grease packed into the wiring box. Should i pull the fuse panel off from inside the cab to check the red wires?
Post by: bd on October 29, 2016, 02:13:24 pm
The black tar-like substance filling the cavities of the bulkhead connector is an antioxidant sealer used to repel dust and water as well as block underhood fumes and outside air from entering the cab through the connector.  You can probe through the sealer from the engine compartment side or probe from the cabin side of the connector.  One of the two red wires passing through the bulkhead connector feeds B+ to the ignition switch, the ECM-B fuse, interior lights, tail lights and horn.  The ECM-B fuse should measure B+ at all times - it powers ECM memory and the fuel pump through the firewall mounted relay.
Post by: tc197 on October 29, 2016, 03:27:31 pm
Bd i love you. While you were writing that last post i found my problem. Randomly in the middle of one of the red wires that goes through the bulkhead i found a spot that split open and was corroded to dust. It wasnt until i ripped all of the black plastic shielding off that i found it. I had b+ at the start of the red wires, but not at the bulk head so thats what lead me to that.
Thank you everyone so much for the help and patience. The truck is idling, the headlights work, you dont even know how excited i am. Ill post up some pics of the wire that was shot for peoples enjoyment.
Post by: bd on October 29, 2016, 06:16:24 pm
Congrats on figuring it out and getting it resolved!
Post by: tc197 on November 14, 2016, 07:56:09 pm
Figured I'd close this out completely and finally get those pictures up of that stupid wire. It's been about 2 weeks now with pretty smooth sailing. I have a slight idle issue when I'm in reverse and occasionally 1st and stopped for either a long period of time or on an incline and it will stall out. I also have a slight take off issue every once in awhile where it stumbles on acceleration and sputters to try and get moving but it's almost at random when it will happen. If it happens it's usually when I first start the truck and it almost always fades out after a few minutes. Regardless it runs, drives, I have headlights, and things are finally moving forward. Thanks for all the help again on this one!
