		73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: aaronboss221 on September 17, 2016, 06:34:52 pm
				Just wanted see who out there has a lot done to their rig and what works well. Currently thinking of building a rig. Not sure if I wanna build my little taco with 1 ton axles or keep it full size with a square body. I live it Tennessee so I will mainly be doing trail riding with rock crawling mixed in. So let's see it yall. What ya got?
Sent from my SM-G930V using Tapatalk
				I have rear shock mount frame braces and heavy duty rear spring shackles from Off Road Design. It's on a 2wd 3/4 ton with a 14bolt full floater 8 lug axle. I've upgraded the suspension for 1 ton capacity so I got these two things from ORD because I thought they were cool haha. Worth the money in my opinion.
(http://uploads.tapatalk-cdn.com/20160918/9cc406855a1ed0b391947d50ddf8fe9d.jpg)
(http://uploads.tapatalk-cdn.com/20160918/a667c0be016183e934fa76f83f1f5220.jpg)
You can find the install of both here.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32761.0
				I definitely like the shock brace   :)
Everything from them is quality, the shackles are heavy. I really liked those, they come with greasable bolts but I didn't want that so I got just the shackles at an even $100. I don't remember how much the shock braces were, it's in my build thread.
				ok thanks    :)
I follow that thread. I really like those. They seem very well built.  I've also seen diy4x. Heard any about them?
				No I haven't.
				meant to tell you before but someone on here had a burb they turned into a trail rig. ill try to find it
found it
http://forum.73-87chevytrucks.com/smforum/index.php?topic=10466.0
