73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: bike4life454 on September 29, 2016, 07:22:36 pm
Title: I need some help....
Post by: bike4life454 on September 29, 2016, 07:22:36 pm
I have been trying to find a replacement for the steering shaft coupling(I'm not sure that's what it is so I circled the part in the picture) but I cent find it anywhere.. If anyone knows where to get it other than a junk yard I would really appreciate it.
http://cloud.tapatalk.com/s/57edb0461c3dd/Capture%2B_2016-09-29-17-10-42.png? (http://cloud.tapatalk.com/s/57edb0461c3dd/Capture%2B_2016-09-29-17-10-42.png?)
Sent from my VS985 4G using Tapatalk
Title: Re: I need some help....
Post by: Irish_Alley on September 29, 2016, 07:57:25 pm
called a rag joint. they sell them at your local parts store for not too much. theres two sizes, should be the smaller size
Post by: bike4life454 on September 29, 2016, 08:57:33 pm
I was under the impression the rag joint was the component closer to the steering box..
Post by: Irish_Alley on September 29, 2016, 09:04:25 pm
sorry cant see the picture due to a firewall. but yes the rag joint connects the steering intermediate shaft with the steering box
Post by: bike4life454 on September 29, 2016, 09:52:53 pm
That's what I thought. But it's the piece closer to the steering column, mine has a shoot ton of play.
Post by: SinisterC10 on October 04, 2016, 11:10:57 pm
That part is called an intermediate shaft steering u-joint.....or steering U-joint for short.
If you were to remove that metal cover and boot you would see a u-joint in there similar to a driveline ujoint....just smaller.
If you can't find one at your local parts store or through one of the resto sites then go to  http://www.borgeson.com/xcart/home.php?cat=34
Borgeson makes top of the line steering parts. If you have to end up buying the entire intermediate shaft assembled then get it from Borgeson instead of a factory replacement or repop part. They are close to the same price.
I would never put a used joint or intermediate shaft assembly from a junkyard back on. Always buy these parts new.
