73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: egleaves on October 20, 2016, 12:18:43 pm
Got off of the highway and stopped at a light. Left light and head a loud "POP" come from front of truck. Pulled over and found cooling fan separated from water pump and coolant spraying from face of radiator. >:(
What would cause the fan to separate from the water pump shaft? I appears to be pressed on and it looked like some of the splines may have been stripped out.
Right now I'm radiator shopping and wondering if I need a new water pump as well.
Please include Year, Make, Model etc.. when posting (http://forum.73-87chevytrucks.com/smforum/index.php?topic=5220.0)
The water pump flange presses onto the impeller shaft. Replace the water pump and fan with quality name brand parts. Make sure that all of the fan retaining studs & nuts are automotive grade and properly tightened.
Year, Make, Model etc are in my signature as always. Thank you.
I'm drawing the conclusion that I will need a new water pump before I'm done with this repair, which especially sucks because the engine and water pump are barely a year old. The fan itself is one of the few remaining original engine parts.
I'm still unclear on the cause of my failure. Could the clutch fail and cause the clutch/fan assembly to come off the shaft? Was I sold a crappy water pump? Or was this somewhat of a fluke?
What are some fan/clutch combos that people have good results with? An electric fan is not in the budget.
When you withhold the vehicle description from the body of your initial post, it forces your readers to hunt for the information and then assume you are working with that vehicle. As a result, you are limiting the number as well as accuracy of responses you'll receive. Simply declaring the vehicle information (even though it is already in your signature) is to your benefit. You're welcome. ;)
Can you post pics? In over 40 years of professional experience, I've never encountered a separation of the water pump flange from its shaft by simply slipping off the end; ...broken water pump shafts, impeller separation, bearing failures, frozen clutches, bent/cracked/broken fan blades, bent/cracked/broken pulleys, missing/broken studs/nuts... yes, but simple axial displacement that resulted in fan clutch separation is new, or at least not common. Be thankful no one was working on the engine when the failure occurred.
Inferior materials and/or poor manufacturing could be the root causes, while any misalignment, wear or damage resulting in vibration may have contributed (e.g., a frozen or improperly mounted clutch, bent/cracked fan blade, loose or missing clutch/fan retaining hardware, bent or broken pulley, etc). Be sure to source decent quality parts in your repair. Inspect all of the parts closely.
What are the high, mean and low temperatures where the vehicle is dominantly used?
Read this:
Wow. Lets move past the point of my truck stats not being exactly where some people would like to see them. They are there.
I'll take a look and try to get a pic when I get home from work, but I know I saw splines exposed. This all happened after dark last night and I haven't been able to inspect thoroughly yet.
I'm in central California where temps swing between about 50 and 90 degrees this time of year.
I'm really starting to question the quality of the accessories that came with the turn-key crate engine I purchased from GM. It's barely a year old and I'm on my second distributor cap, the starter housing exploded this summer, and now this with the fan.
Have you determined whether there is any warranty remaining on the water pump?
So, Summer temps can soar as high as 113° F and in Winter drop as low as 20° F. Summer temps are the more important extreme to reconcile, especially if you use your truck for towing or hauling heavy loads during the warm months. Install a severe-duty fan clutch, such as available from Hayden (https://www.summitracing.com/parts/hda-2797) in conjunction with a Derale (https://www.summitracing.com/search/brand/derale-cooling-products/product-line/derale-clutch-fans/rotation/clockwise?N=400434%2B305413%2B4294949147&PageSize=100&SortBy=Default&SortOrder=Ascending&autoview=SKU&ibanner=SREPD5) fan blade, both designed for clockwise rotation. Measure the existing fan diameter and procure the replacement with at least as many blades, but no fewer than six. The severe-duty clutch and fan should move significantly more air than the original, but will result in increased noise with a slight decrease in fuel mileage. The "wind" noise will be more pronounced when the engine is first started in the AM. Use an AC Delco service replacement water pump, or a Milodon (https://www.summitracing.com/parts/mil-16212) high-volume iron pump. Don't rely on the linked part numbers without further research on fitment. Of course, other brands and combinations may also work.
Did the fan separate from the water pump flange? Or did the flange itself (with the fan) separate from the water pump?
Turns out the fan clutch separated from the spindle that then bolts to the water pump flange. The water pump is intact. It appears that the point of failure was the clutch/fan assembly. The two pieces were pressed together (poorly?) and in the end the internal splines were stripped out of the clutch. What bothers me a bit is this....the dealership that installed the engine used the fan blades from the original engine and a new clutch. The fan blades are installed between the two pieces that just separated from each other, which means they were pressed together at the dealership. Right?
I'll work on posting a few pics.
Interesting. My motivation for having this engine installed was to pull a 30' travel trailer from Ohio to Florida to California. I did that. The engine left Ohio in October just as night temps were dropping below freezing. 4 weeks later it was in the Florida Keys where 70F was "cold". 4 weeks later it was in Phoenix, Arizona where the weather man can't count below 70. It has since been through a central California summer. So, now that I think about it the engine has seen plenty delta T.
Should there have been grease inside a pressed together assembly? The splines were covered in a light-gray grease. I have pics but I can't post them until tomorrow.
Well, I've been discussing a Gen I small block and just woke up to the fact that you have a Vortec. Different animal. Post pics. The "gray grease" is probably anti-seize.
Posting pics. Probably in random order, I don't know. I'm not good at putting pics on these fora.
The pics certainly clarify the issue. The fan clutch came apart. The 'gray grease' is the silicone fluid that makes the viscous clutch function. Now, you need to determine whether it was a manufacturing defect or if there was a vibration that contributed to the separation.
Clarify the following: When you unbolted the clutch stub shaft from the water pump flange, were all of the bolts tight? Any missing - I see three? When you removed the four bolts that retain the fan to the clutch, were they tight? Describe the fit between the fan hub and the clutch. Is it snug and concentric without the bolts installed? When you place the stub shaft into position on the water pump flange, is it a snug fit on the pilot? Grab the water pump flange and wiggle it side-to-side. Is there any radial movement?
Edit: restated the questions after closer inspection of the images.
bd, you are very thorough.
I unbolted the stub shaft from the water pump flange. All three bolts were there and tight.....kidding! All four bolts were tight.
I also removed the bolts that hold the fan to the clutch and again, all four bolts present and tight. So far everything aside from the point of failure has felt tight and snug, but I haven't tried to wiggle the water pump yet.
might be a stupid question but is that one of those reverse rotation water pumps? if it is and they used your original fan it might have been turning backwards
Irish makes a valid point. When you get a chance, post a pic of the belt configuration and routing. It's important information to ensure the correct rotation replacement clutch and fan.
its a stretch but if the dealer installed the wrong fan on their own without informing you its the wrong one and had you sign off, they should be responsible for it. but the cost of a rad and fan will be far less than taking them to court
Yeah, I could probably prove GM to be at fault for something, but it would cost me more to go after them than to just eat the cost of parts.
I picked up a radiator today and going to install it tomorrow. I haven't bought a new fan yet so I'll verify the rotation tomorrow also.
Thanks for the ideas and input.
I've worked on a lot lot of cars in my life
Never seen that problem
I drove myself to work today! ;D
I verified the water pump rotates counter clockwise and learned the old fan was rotating the right way, but I haven't been able to verify which way my exploding clutch was supposed to rotate.
It appears that my original engine was standard rotation (CW), and my new engine is CCW but the dealership used my original fan on the new install. They must have installed the fan backwards to get the rotation right! Can you do that? I know fans have a direction, but what are the ramifications of installing a fan backwards as long as its blowing air the right direction?
What if the exploding clutch was a CW rotation unit that has been running on a CCW water pump with a CW fan installed backwards?
Also, is there any way to verify the correct rotation of the old clutch? There are no helpful markings on the outside.
Generally, the fan hub rolls gently forward at its circumference toward the clutch body when properly installed. Automotive cooling fans are designed to rotate in one direction only. They won't perform correctly if reversed. The old clutch may have a part number (or partial number) stamped on it.
looking at your fan picture of the broken clutch it looks like its on correctly and is a ccw rotation fan which is odd cause your OEM fan should have been CW rotation and theres no way to install it backwards like bd said
I've been trying to educate myself on exactly how the fan clutch works so that I can understand how it might fail. None of the "tutorials", or "how-does-blank-work" articles that I have found really go into what is happening on the inside. I get the whole concept of the bi-metallic spring opening a valve and allowing fluid to flow, but does this mechanism work more like a plate type clutch that relies on face-to-face contact, or more like a torque converter with vanes? I'm guessing more like a torque converter with some sort of vanes to transfer the forces from one half to the other. Then I'm wondering if those vanes are directional. Then I'm wondering if it was running it backwards for a year and it wore out prematurely.
Anyone ever been inside of a thermostatic fan clutch far enough to see whats going on?
this is what im thinking. most of us havnt seen this type of issue i dont think weve dealt with a clutch being incorrectly installed for the rotation. but im still confused on how the fan is correctly installed when it shouldnt have been if they reused your old fan. was your old motor V-belt or serpentine?
this is what im thinking. most of us havnt seen this type of issue i dont think weve dealt with a clutch being incorrectly installed for the rotation. but im still confused on how the fan is correctly installed when it shouldn't have been if they reused your old fan. was your old motor V-belt or serpentine?
The old engine was a typical V-belt. New engine is serpentine.
Something I've run into with this truck is that it is apparently some sort of "half-year" model. Last winter I went to replace the blower motor with a part for a '74 only to find (the hard way) that I needed a blower from a '75. I'm told I might run into more parts like that in the future. I just looked up a water pump for a '75 and it is still listed as standard rotation.
The only thing I can figure it that they turn the fan blades around backwards, which would move air in the right direction, but at what cost?
afaik they didnt do the reverse flow till they went to serpentine system and if the pulley was smooth it would turn the opposite way of the crank which was 88+. the blades cant be turned cause the fan housing is bent to form around the clutch. im sure you could flip it but this would put the blades a couple inches towards the engine and into the belts/pulleys
...Anyone ever been inside of a thermostatic fan clutch far enough to see whats going on?
See PROPER WAY TO TELL IF CLUTCH FAN IS WORKING? (http://forum.73-87chevytrucks.com/smforum/index.php?topic=32134.msg270999;topicseen#msg270999).
Are you sure the dealer didn't install a new fan blade and reuse the old viscous clutch? It would surprise if a dealer made that mistake, but dumber things have happened. Inspect the old fan clutch for any numbers that might be useful in identifying it.
You might find the vehicle production date imprinted on the SPID or door plate.
I'm positive that they installed a new clutch and used my old fan. I'll look closer tonight for markings.
So the inside of the clutch has concentric rings instead of vanes or blades, and the viscous fluid transmits power through fluid shear. That suggests to me that the direction of rotation isn't important to the clutch mechanism. But if that were true there would be no reason for us to select a different clutch for CW vs. CCW. What is it about a fan clutch that makes it care which direction it is rotating? Something about the valving or the fluid path?
Rotation controls the migration direction of fluid through the clutch and valve. AFAIK, a clutch that spins backward will not engage effectively. A reasonable question might be whether the clutch hub would starve for lubrication in the process. Even so, I wouldn't expect the spindle to separate from the clutch. But you would experience overheating for lack of sufficient airflow over the radiator.
