73-87 Chevy _ GMC Trucks => Interior & Equipment => Topic started by: temains on November 09, 2016, 04:53:25 am
Can I run new 6x9 speakers in my cab corners and keep my stock head unit?
Sent from my SAMSUNG-SM-G900A using Tapatalk
I don't remember how many outputs are on the stock unit, but it shouldn't matter otherwise.
Sent from my LGL34C using Tapatalk
pretty sure you can but theres a conflict between the new speakers and your old head unit. cant remember off hand but try the search
Does anyone know if i can run new 6x9s in my cab corners off my original radio
yes you can run 6x9's
Yes, you can run 6x9's in the corners. Did you know you can also add bluetooth to your old stock unit? It's pretty cool (and cheap)!
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32675.msg277070#msg277070
The stock radio uses 10-16 ohm speakers. Many of the speakers out there are 4 ohm causing a lot of strain on the Delco stock radios. While it will work that is the leading cause of stock radio's to stop working.
this is what i was talking about. thanks zieg
