73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: mrjata on November 13, 2016, 11:26:51 pm
Title: Frame numbers, what do I have?
Post by: mrjata on November 13, 2016, 11:26:51 pm
Got a frame for parts but I need to know what I have for sure.  He "said: it was an 84 1/2T but I need to run the numbers to make sure.  All I can find were numbers stamped on the side of the frame about at where the tank would be or the catalytic converter would be.  Are these of any use??
14055623
180 84 180 2 892
CES189908
What do I have?????  HELP.
Thanks all,
Title: Re: Frame numbers, what do I have?
Post by: Engineer on November 14, 2016, 06:36:37 am
1st number is a GM part number. Most likely for that particular frame rail and not the entire frame.
3rd number is the sequence number from your VIN. The "S" denotes that your truck was built in StLouis, and the 6 numerals are the production sequence number. This number should match the number stamped into the tag pop riveted to your dash, and on the truck's title.
The 2nd number is probably a production date code. Or it could be missle launch codes. Not sure. But most likely a date code.
Title: What year frame??
Post by: mrjata on November 17, 2016, 12:02:01 am
I got a donor truck but I need to know the year for sure.  Can you help a guy out?  I have looked all over the net, no luck.
The numbers on the top of the frame on the passengers side about at the cab/bed are:
CES189908
The numbers on the driver's side of the frame facing out at about the catalytic converter are:
14055623
180 84 180 2 892
Does any of this help??
Title: Re: What year frame??
Post by: 1967KaiserM715 on November 17, 2016, 05:34:37 am
The ces number is the vin sequence code, look up how to read a vin and that should tell you the year and plant the truck was manufactured
Post by: Irish_Alley on November 17, 2016, 07:22:41 am
please do not make mulitple post on the same subject. if its all on one post we can work together and see what others have stated and confirm or deny whats been said
Post by: mrjata on November 17, 2016, 09:35:58 am
I didn't double post on purpose, I have had several glitches show up from this page to me.  I wonder what I have going on??
Post by: bd on November 17, 2016, 08:42:40 pm
14055623 is the GM part number of the left frame rail for 1984 2-door, two and four wheel drive, 1/2-ton chassis (C/K10) with 131.5" wheel base.
Post by: mrjata on November 17, 2016, 09:26:07 pm
THANK YOU!!!!  I appreciate it so much!!
Post by: roundhouse on November 17, 2016, 09:26:23 pm
My truck is a stolen recovery with a state issued VIN and every number has been ground off the frame , engine , Trans etc
No clue what year it is
