73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: philo_beddoe on November 15, 2016, 12:32:51 pm
Title: Wheel spacers
Post by: philo_beddoe on November 15, 2016, 12:32:51 pm
VZ mentioned i would have better drivability with wheel spacers, and i wouldnt have that sunken in look. I checked summit and got confused on all the styles and types. Any recommendations on some plain black ones, not billet? 1" i guess? Basic 5 lug pattern.
Title: Re: Wheel spacers
Post by: Irish_Alley on November 16, 2016, 09:19:16 am
think they offer the two styles for different wheels. if you can see through the wheel you want the spacers to match. if you cant see though i would go with the cheaper ones if theyre the same price it doesnt matter
Post by: philo_beddoe on November 16, 2016, 01:32:37 pm
Cant see through. But wont it take away thread space for the lug bolt? I'd like to bring out an inch, unless advised otherwise. I may see VZ this weekend, i'll ask him details. Drop by for coffee and low fat BB muffins.
Post by: Irish_Alley on November 16, 2016, 01:44:47 pm
whith the one inch yes but the 1.5 no cause it has studs built in.
https://www.summitracing.com/parts/tgi-141051-3-kit
Post by: Irish_Alley on November 16, 2016, 01:56:54 pm
even the 1.25 come with lug nuts
https://www.summitracing.com/parts/cal-75817/overview/
Post by: philo_beddoe on November 16, 2016, 03:34:52 pm
Thanks irish, i'm thinking 1.25". My studs wont go beyond the holes on the spacer right?
Post by: VileZambonie on November 16, 2016, 05:22:39 pm
I only have 5x5 by 5x4.5 and 6lug in stock.
Post by: philo_beddoe on November 16, 2016, 08:02:20 pm
Ok. So what size are mine? Can we install those too while were at it?
Post by: Stewart G Griffin on November 17, 2016, 06:09:34 am
How do you figure better driveability?
Post by: philo_beddoe on November 17, 2016, 02:10:02 pm
Very simple, whatever VileZambonie says about 73-87 chevy trucks is correct. Lol...
After he figured out this nasty vibration i have, not to mention the really bad one last spring which no other mechanic could figure out, i trust his judgement and advice. I can understand it, but cant put in words why a wider wheelbase would handle better.
Or maybe its like this, your more stable with your feet spread a little apart than with them close together.
I know there are others on this site that are really savy with the mechanics of these trucks,  its just that i live near VZ and he's the only one that has ever worked on my truck.
I sure wish some others on this site were within a few minutes drive as well, VZ often gets slammed busy.
Post by: philo_beddoe on November 18, 2016, 08:38:11 am
Tim, so how do we install this style? Seems like the stud will be covered too far, or does the lug bolt sink inside the spacer???
https://www.summitracing.com/parts/aaf-all44123/overview/
Post by: Irish_Alley on November 18, 2016, 08:55:09 am
imo yes they would cover the studs too far. afaik they dont make longer nuts so i dont know how they would work. which is why i suggested the other style. if you have the open style lug nuts and you can only see .25 or .50 of the stud sticking out that would be as much of a spacer maybe a little smaller that i would install
Post by: Irish_Alley on November 18, 2016, 08:56:17 am
even if they offer longer studs theyre going to be $2 each for the normal size ones and you would need 20 so thats 40 more dollars plus the spacers and shipping youre looking at what 70-80?
Post by: philo_beddoe on November 18, 2016, 10:21:43 am
Ok, i'll go with the ones you suggested. Thanks..
Post by: VileZambonie on November 18, 2016, 08:17:18 pm
Post by: philo_beddoe on November 18, 2016, 09:55:57 pm
Ok, now that will work. But who offers that one for sale?
Post by: VileZambonie on November 19, 2016, 07:35:40 am
I have a supplier if you want them.
Post by: LTZ C20 on November 19, 2016, 09:05:12 am
I would go with what VZ's supplier has, then if you don't like the color, simply paint them.
Post by: philo_beddoe on November 19, 2016, 02:16:20 pm
What do they cost per pair?
Post by: VileZambonie on November 19, 2016, 05:06:08 pm
Post by: philo_beddoe on November 19, 2016, 05:41:41 pm
Lol!! Thats what i figured! "Wow a classic chevy truck, thats cool, those are easy to fix, i think i'll buy it." What was i thinking, i shoulda got a used tacoma...lol
Post by: Captkaos on November 20, 2016, 09:51:29 am
I run spidertrax for spacers,  Never ran any on 73-87 though.
Post by: philo_beddoe on January 30, 2017, 01:04:47 pm
This truck could use some spacers. And i thought my wheels were sunken in...
Sorry, had to remove pic.. anyway it was a low ryder, real low...
Post by: philo_beddoe on February 27, 2017, 09:26:16 pm
I was advised that wheel spacers can do a number on the wheel bearings. Especially if you go too far out. Is that right?
Post by: VileZambonie on February 28, 2017, 11:49:01 am
So by that logic, everyone who runs aftermarket wheels with that offset must have bad wheel bearings.
Post by: philo_beddoe on February 28, 2017, 02:47:59 pm
Maybe they do and dont know it? Lol
Just what i heard, thats all.
Post by: big_al273 on February 28, 2017, 03:03:30 pm
No, but running wheel spacers moves the tire Off-center of the wheel bearing causing leverage and additional directional forces in the bearing, small differences in back spacing won't have any noticeable effect but say you combine some factors like a large curb weight, over-sized tires and excessive backspacing and you can cause the forces exerted on the wheel bearing to exceed the capacity on the bearing either resulting in reduced bearing life or complete failure depending on how much force in applied. So while wheel spacers or rims with back spacing will not automatically kill wheel bearings you should take into account that the more spacing you have the higher the strength of the forces that your wheel bearings will have to deal with Very much like how bigger tires add stress to the drive train and transmission, there are also other factors that I didn't go into take a look at this: http://www.fourwheeler.com/how-to/1110or-truth-about-wheel-spacers-safety/
