		73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: SinisterC10 on November 22, 2016, 04:03:44 pm
				I have a 1981 2wd truck and am wanting to know what bore size the master cylinder and brake booster is? I don't have the ID sticker in my glove box so I can't look it up. I'm going with 4 way Wilwood discs and want to replace the old booster and master.
				in 81 the sticker is on the drivers side inner fender well under the hood.
 Mine is missing.
				The forth digit (letter) tells you what brakes you have
 http://www.73-87.com/7387info/8187vin.htm
 My vin has a "D", but that's not going to tell me what bore sizethe MC is. I took a dial caliper and the inside bore measures about 40mm or 1.57". I still need to know if this is considered a jb3 or jb5 system.
				http://forum.73-87chevytrucks.com/smforum/index.php?topic=28592.0
 JB3 will have 1" rotors and JB5 will have 1.25" rotors, both share the same master cylinder it seems.
				jb 1 had the 1.417" bore while jb 3 and 5 had the 1.574"
				Thanks for the info guys. I've decided to put a Hydratech Hydroboost system in the truck. I have one that I had on my Camaro and am going to have Hydratech change out the mounting plate and pedal rod. Gonna cost me about $275.
