73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: Jerr-conn on February 23, 2017, 10:02:56 am
I am removing stainless steel stone guards from in front of rear wheels on my 87 fleet side.
There are only ( 2 ). 1/8" holes on each side. What is best is way to eliminate these holes
Without welding holes shut. Thanks.
you could use a plastic/rubber plug. like an interior part(door panel or something) you could also put a bolt and nut through it if you can get behind it. neither of those look pretty though lol
thats a small hole ive seen bigger holes filled with body filler then sanded and painted. its not the best way but its simple and easy
Temporary band-aid seam sealer
