73-87 Chevy _ GMC Trucks => Electrical => Topic started by: erniec on March 02, 2017, 10:10:19 am
Title: Ignition Switch - Actuator
Post by: erniec on March 02, 2017, 10:10:19 am
I have a 1973 Chevy Stepside.  I had a tilt wheel that was very loose and when tightening I found several broken parts.  I opted to replace the entire steering column with a used non tilt style.  I have two different switches I have tried but neither seem to work.  The actuator rod doesn't line up with the switch.
Any thoughts?  One switch I have would work if it had an opening on the underside.
Thank you
Ernie
Title: Re: Ignition Switch - Actuator
Post by: Captkaos on March 02, 2017, 11:42:46 pm
Did you buy the correct switch?
