73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: JWM_longbedc10 on April 25, 2017, 11:28:47 pm
Title: K10 lift for c10
Post by: JWM_longbedc10 on April 25, 2017, 11:28:47 pm
Hey yall, im new to this forum and have a question regarding suspension. I have a 1980 c10 and am having trouble finding a lift kit for it. I want to do a 4 inch lift and all i can find is lifts for k10s. Would a k10 lift work on a c10? If not what else could i do to add some height. Thanks!
Title: Re: K10 lift for c10
Post by: 1967KaiserM715 on April 26, 2017, 05:02:04 am
No way you can lift a c10 4 inches, you can run 1 ton front coil springs with a little work. Gets roughly 2" lift.
Or you can convert to 4wd, then it would look right.
Post by: JWM_longbedc10 on April 26, 2017, 12:35:07 pm
Would that be enough to fit 35s? What about new leaf springs, current ones are kind of sagging
Post by: Al-Haqq on April 26, 2017, 01:39:57 pm
@JWM_longbedc10 I have the same issue. I have a 86 C10, and would let to lift it, but was told the same thing bout the 1ton springs.
Sent from my Z956 using Tapatalk
Post by: Stewart G Griffin on April 26, 2017, 02:15:54 pm
You may want to research what the donk crowd is doing to get caprices, monte carlos, cutlasses etc. up very high.
.....or not.
Post by: 1967KaiserM715 on April 26, 2017, 03:39:08 pm
Is your truck 2wd or 4 wheel drive?
Post by: JWM_longbedc10 on April 26, 2017, 10:42:48 pm
its 2wd
Post by: 1967KaiserM715 on April 27, 2017, 05:09:37 am
Ok, so fronts are coil springs, rear are leaf springs
I would say with 1 ton coil springs you may be able to fit 33" tires, you could do a body lift, and that could net you a few extra inches to fit 35" tires.
Post by: JWM_longbedc10 on May 01, 2017, 10:34:56 am
Thanks, would a 3-4 inch body lift alone clear 33s or maybe 35s?
Post by: 1967KaiserM715 on May 01, 2017, 04:45:47 pm
I would say with a 3" body lift you could definitely fit 33" tires, not sure on 35" tires though.
Post by: roundhouse on May 01, 2017, 11:45:23 pm
I'd start with a 2" block on the rear springs
And or maybe new springs
The 4 wd rear leafs should fit a 2wd
On the front the one ton springs should get some lift but you could use lift coils from a 4wd vehicle with coils in the front , like a bronco
But living much is going to totally screw up the suspension geometry
But people have been building pre runner type 2 wd pickups for 40 years so it can't be that hard
Hockey pucks are a cheap one inch lift
I wouldn't do more than a 2" body lift
And even that is going to require modifications with the shift linkage , brake lines , steering Column, wiring harness  etc
You can also trim the fenders a little at the bottom corners
Googling "c10 prerunner " and "c10 pre runner "
Brings a lot of info and pictures
Post by: Irish_Alley on May 03, 2017, 09:03:03 am
you can get lifts for the 2wd. they dont make them for our trucks anymore but you can use the lifted spindles from a 88-98 2wd but you have to adapt your truck to the 88-98 style. but im not sure what you have to change, theres a few on here that know the details
AIM industries used to sell 2WD lift kits, and someone has used a 88-99 2WD lift on our trucks...
Rear would just be a std 2.5" lift blocks
Need Bilstein 5100 extended shocks
For the Front:
88-98 Rough Country lift spindles
88-98 Raybestos PG ball joints
88-98 C2500 LD 6 lugs rotors and calipers
Moog 6454 HD Springs
73-87 C30 lower A-arms
73-87 C10 upper A-arm
You will need to ream out the spindle to fit the 73-87 Tie rod ends...
Other than that, your only option is using 1T coils in front and lift springs in the rear.  How big a tire are you wanting to go to?
Post by: Irish_Alley on May 03, 2017, 09:19:48 am
better yet
http://67-72chevytrucks.com/vboard/showthread.php?t=447061
(http://67-72chevytrucks.com/vboard/attachment.php?attachmentid=686540&stc=1&d=1295750231)
(http://67-72chevytrucks.com/gallery/data/890/medium/21872224016_large.jpg)
Post by: Irish_Alley on May 03, 2017, 10:29:35 am
according to my math thats about 1192.83 to get the parts for the 5 lug. now saying that you might be able to find a donor 92-98 c1500 and use most of those parts and save
Post by: JWM_longbedc10 on May 06, 2017, 04:25:57 pm
Thanks for the help, what about leveling the truck?
Post by: Irish_Alley on May 07, 2017, 07:49:48 am
cant say for sure but one option is to remove a rear spring
Post by: Jeffs_sledz on May 27, 2017, 12:29:09 am
Here is what 1 ton front coils look like installed. other than that my truck has stock suspension. I'm running 33" tires on it currently. No cutting of the fenders needed. No rubbing when turning either.
