73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: Jakethesnake73 on May 04, 2017, 12:15:05 pm
Title: Ball joint wear? Whats acceptable
Post by: Jakethesnake73 on May 04, 2017, 12:15:05 pm
My passeger side is good but the driver side moves a little. You cant hear it hit when you check them but put you hand on the tire and you can feel it slightly. Will an alignment hold
Sent from my SAMSUNG-SM-G891A using Tapatalk
Title: Re: Ball joint wear? Whats acceptable
Post by: zieg85 on May 04, 2017, 12:49:41 pm
Any movement is no good and any reputable shop will not align it with worn parts
Post by: Irish_Alley on May 04, 2017, 02:18:28 pm
could it be your wheel bearing/s?
Post by: big_al273 on May 05, 2017, 10:17:24 pm
replace the worn component then get your alignment
Post by: Jakethesnake73 on May 11, 2017, 10:42:21 pm
Ok sounds good thanks!
