		73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Spool on May 11, 2017, 04:42:43 pm
				Hey guys,
73' c20 here.
I'm leaking oil from my pan and believe I need a new oil gasket.
Went to autozone and they asked if it was
-with exhaust pipe packing or without?
Would you guys happen to know?
				Try orileys. . My luck with autozone is the don't know anything about cars or trucks
Sent from my SAMSUNG-SM-G870A using Tapatalk
				Are you sure the oil pan is leaking rather than running down from above?  Have you verified oil isn't leaking from the intake manifold valley, or the valve covers, or the oil pressure sensor, or rear main seal, or the oil filter, etc.?
1973 C20 with 350 engine - oil pan gasket:  Try a Fel-Pro OS34509T (http://www.oreillyauto.com/site/c/detail/FEL0/OS34509T/02296.oap?year=1973&make=Chevrolet&model=C20%2BPickup%2BRWD&vi=5134602&ck=Search_oil+pan+gasket+set_5134602_3557&keyword=oil+pan+gasket+set#compatibilityTab_) one-piece gasket set.  The question regarding exhaust packing relates to vehicles that require removal of the exhaust crossover to gain suitable access to the pan.  Some gasket sets come with the exhaust packing, some without.  If you have single exhaust, you will probably need it.  But, you can always procure exhaust packing separately if necessary.
				The one piece is the way to go if that's what you need.
The oil likes to drip from the pan and is most noticeable when parked. It runs along the sides and pools in the center before dripping.
The engine block looks clean from the intake manifold and rear main seal.
AutoZone had the Fel-Pro available, I'll go with that.
Thanks guys.
