73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: AMSRocker on June 14, 2017, 10:08:41 am
So right now I have 15" rims and they don't look bad at all.
Let's start with what I DON'T want!
- I don't want rims so big that the tires look like slightly thicker rubber bands snapped on the rims.
- I don't want rubbing from my front tires on my fenders!!!!!!
What I DO want:
- I want some rims and tires that look balanced well where the rims and the tires work well with each other
- I want a bit of a sport/mussel look but tires that are not too wide to make them look like a Formula 1 racing car.
Can you guys with 17" rims please post some photos of your rims please!
FYI: I will be using the factory coils and leaf springs. The front coils have sagged a pinch over the last 40 years but that gave the truck a nice gate to it! Most likely a 1" drop in the front. The rear leaf springs are the 3/4 ton spring pack from the factory. I got a heavy half ton truck.
I also have a 12 bold rear end and my studs are a 5 by 5"
Thank you in advance guys!!!!
PS:
Something that I have found out in looking for 15" rims. I have been told a few times over by local tire shops is that the 5 by 5" rims are limited to a few styles of rims. This is because of the Jeeps. You see the majority of the 5 by 5" market was pushed to the Jeep market and that limited the rims to larger rims. There are a number of 5 by 5" rims but if you look at them they all for the most part look the same. That Crager SS look and that is the look that I DON'T want!
Here is an older picture of mine with 17" rims. Stock ride height '77 K20. Tires are 33" tall, so I have 8" of sidewall.
(https://lh3.googleusercontent.com/Xpwzel_M41nET8nxj_4Gr4CJIgT5zx_m79vBOa5MDeWi5NqoOMg-elqTAK6X9aJQL8EWMj0bhTR4xojYvD_DAqj7_oCM0rGnhAU_3O6Xs2bW7gDB80v-nWfY1THYo2z64CtbF10XM2rSgFimEjlgLZOWVWhvySDAzorV03HszJSqdcYdwjwDx2yk8ZO2WqtRLo3MVcTAJVlYqfZSnIYkQDlobQD8YAwL1usTqon47JjO0rXXWCu7fNMczXD9mFaWQk5qZI5BZFWXM-ZwR8XUwSq297bVR2Y04maj6uT-zq2Uj7aNZ_XTyWQOkDshupAQo-GhIfaBvx66zw0VyJkAaCHhHeXFAxeMcXzax5mM--mCGrJUCI5ueIpm5AR4UbK6VhNtaPLJCbZGS5nH_ANCMdXsWGZ2-tKeWwTAOy25b2W4H-JO1Rgk_93bRehnfwjCWLmiDE9q2edUDvpec1EcPTH3j5kheC_7HtxKcm83InTUeYFZeNhYHosoxlry4uis9CIh9rq6mVROfDvO_oG07sc9EC_1QjSLdyeh7mFbr8neneAYmGtLGAOfuGpygMnq_lpJYPYujGa4GyRHQrvjSl8f8GWM9bNrRssyNiGtLgw3v_7m2idC=w1512-h1134-no)
Thank you very much for taking the time to respond!
Looks like there is a bunchy of room there and little to no chance of rubbing.
Sounds like you need some 15" slots
https://www.summitracing.com/parts/are-vna695873/overview/
That's the stance I want (level). But I haven't had any luck finding away to lift my sagging front end. I have a heavy 1/2 as well. I couldn't find any 16 inch tires I wanted there like finding a dinosaur
285 75 16..(https://uploads.tapatalk-cdn.com/20170616/aa1858126a89ca9fcec070a24cefd0f9.jpg)
Sent from my SAMSUNG-SM-G870A using Tapatalk
stock height with Impala SS 17's
(http://forum.73-87chevytrucks.com/smforum/gallery/2_31_03_09_5_51_25.jpeg)
2/4" drop same wheels and tires:
(http://www.73-87chevytrucks.com/projects/87R10-Driver/R10drvr_406.jpg)
What is the tire size of the Impala SS tires?
Thanks for the reply!!!!
should be 255/50R17 stock
The ones on mine are 275/55/17.
