73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: Stewart G Griffin on July 16, 2017, 07:42:03 pm
Title: Grease/zerk fittings:
Post by: Stewart G Griffin on July 16, 2017, 07:42:03 pm
Sorry, but how many lube points are on the front end of a 1/2 ton 2WD?
Title: Re: Front end lube points?
Post by: dphipps on July 17, 2017, 08:14:20 am
Tie rods and ball joints were the only greasable items on my original parts, idler and pitman were not greasable. The replacement idler and pitman I used are greasable. (moog "problem solver)
Post by: jetman on July 17, 2017, 10:27:18 pm
Depends on how many cheap replacement parts you have, grease all you can find.
Post by: Irish_Alley on July 20, 2017, 12:21:40 am
gotcha fam
(http://forum.73-87chevytrucks.com/smforum/index.php?action=dlattach;topic=35335.0;attach=36818;image)
Post by: Stewart G Griffin on October 30, 2017, 11:35:35 pm
Please list ALL grease/zerk (if zerk is the same as a grease fitting) fittings and locations on a 2WD truck.
Title: Re: Grease/zerk fittings:
Post by: Henry on October 31, 2017, 08:14:52 am
Hi Stewart:
My 76 C-20 2wd, 350V8, TH400 auto trans, has the following grease fittings:
1. Upper control arms(4)
2. Lower control arms(4)
3. Upper and lower ball joints(4)
4. Steering idler arms(4)
5. Tie rod ends(2)
6. Forward drive shaft u-joint(1)
7. Rear drive shaft u-joint(1)
8. Drive shaft slip joint(1)
This is 21 grease fittings...some models of 1976 may not have had #8 because of different transmissions. Some models may have a grease fitting on the steering shaft between the steering column and steering gearbox.
Regards,
Henry
