73-87 Chevy _ GMC Trucks => Engine/Drivetrain => LT/LS Swaps => Topic started by: kylen52 on July 17, 2017, 03:27:56 pm
New to the forum, wanting to put a 99 5.3 out of a gmc in my 1985 Chevy c10, would like to know yall's opinion on the parts I'll need, I've got a pretty good idea of the parts I'll need I just wanna make sure I'm not missing anything
Sent from my SAMSUNG-SM-G900A using Tapatalk
Guess no one is gonna help me out
donor engine
donor harness
conversion mounts
replace all rubber fuel lines with F.I. rated hose and hose clamps
custom flex lines to run from hard line in frame to engine
high pressure electric fuel pump
A 5/16" return line to the tank if you don't already have one.
MAF Sensor and intake duct work
Some sort of exhaust work...headers...downpipes, etc. with bungs and O2 sensors
Stand alone DIY electrical harness with fuses and relays to power it...or buy a custom harness
PCM and reprogramming for your vehicle
Some sort of radiator work to either install a steam line port or use the JTR adapter to plumb the steamline
Maybe an A/C relocation kit if you have A/C and intend to retain it.
Accelerator pedal cable to go between your pedal an the throttle body
Some supplies to plumb your power steering, etc.
And maybe the Vacuum booster quick connect fitting at the back of the manifold if you don't already have that. Some come with a plug for vehicles that had hydroboost.
I've already got the motor and transmission, plan on putting a stage 4 cam low lift in it, and maybe eventually supercharging it
Dual tanks? You might want to get new '87+ tanks and go with the in-tank pumps. You can retain the switching valve, but you have to be sure it is the upgraded one that can handle 65 psi fuel pressure. Pollak was the manufacturer that made the switching valves. They still make the 42-154 6-port switching valve.
What about a drive shaft? Or will I have to get one made
Totally depends on what you are starting with and what you are going to for a drivetrain. You can keep the back of the LS engine block in the same position as the stock engine. Then it comes down to the length of the transmission. If the transmission you are going to is longer, then you can have your current driveshaft shortened. Depending on what yokes you have you might need to change those out, or get a conversion U-joint. If the transmission is shorter, then you can't lengthen a driveshaft per say...you will have to have it re-tubed. That is a little more expensive as they totally replace the entire length of the driveshaft tube with a longer one.
My grandpa owns a salvage yard, I'm sure I can come up with some yokes
We used
http://www.team208motorsports.com
To do the tuning
We did the harness mods ourselves but for the next one we are gonna have team208 do it
I highly recommend him
He does a lot of tuning of race trucks , in real time with a cellphone telemetry setup
After each short course he will download the data and retune the software for that specific course , tires, gear ratio, etc
He mods it and adds a fusebox with three or four wires to hook up and you're running
There's a lot of articles on the web about what parts you need
It varies a lot depending on the donor and if you have drive by wire or cable etc
We used late model camaro exhaust manifolds
We flipped the injector rail to put the hose connections on the front passenger side
Takes an hour with a sawzall and dremel to removes some tabs from the intake but it worth it if you want to have your fuel lines on the passenger side
Get an 87 tank from rockauto.com
Modify the late mode pump to fit inside .
There is no one article that's going to cover everything you need to do
Just too many variables
Use using a slushbox or a manual transmission ?
We used a NV-3500 from a 07 Silverado and love it !
I have a NV3550 in my 74 Bronco and it's a blast
If you want to use an auto then pull the engine and Trans from the same donor vehicle
Don't try to mix and match
From different cars
We used a stock 2002 5.3 with 270k on it with no mods
Just changed the intake , valve cover and oil pan gaskets
Once your Tuner deletes the torque management (GM can't make an auto Trans that will last behind a V-8)
And deletes the emission software
You would be surprised at the power of a stock high Milage LS
Ours has easily double the power of the 4 bbl 350 it replaced
The rear exhaust manifold bolts WILL snap off when you try to remove them
GM used glue on them for some reason
Heating them with a torch before you try to remove them may help but probably not
So be prepared to drill them out and clean up the threads with a tap
Everyone worries about the driveshaft
That's the easiest mod
Before you remove the old one Measure carefully from center of the U joint caps on each end
When then Trans is in measure from the same place
Take your old shaft and $100 to a driveshaft shop and have them shorten and rebalance it
You will spend more money and lot and lots more time on the fuel lines and fittings and filters and tank
I've heard the fuel lines take the longest, watched a guy on YouTube and I liked his idea, probably go with his set up, the motor im going to use is out of a 99 gmc, and the trans is out of a 99 chevy, which is a cable not drive by wire
haven’t posted in a while but here’s some pics(https://uploads.tapatalk-cdn.com/20171211/19dacb1cf40a773253ab4edccd1cf3da.jpg)(https://uploads.tapatalk-cdn.com/20171211/325fcb88d922f15e20735f77c8b5cc99.jpg)(https://uploads.tapatalk-cdn.com/20171211/cd9765fc75218666d0f2454464f48a35.jpg)(https://uploads.tapatalk-cdn.com/20171211/30ff1e5108cf559bb08aac724794ea26.jpg)(https://uploads.tapatalk-cdn.com/20171211/ad51f7f5106887109b1550459885ee50.jpg)
Making progress! Good job! My Crew Cab LS has slowed down. I need to paint my front valance panel, make up my oil cooler lines and get a replacement oil cooler, finish the exhaust and then wire it! The holidays have been interfering with all of that!
yea i’ve done all about i’m gonna do to it until after Christmas, but i plan on having it done by may 2018
