		73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Brakes and Braking Systems => Topic started by: Jerr-conn on August 20, 2017, 05:10:08 pm
				Topped off brake fluid yesterday. Didn't realize it was dot3 synthetic. Am I supposed to have
 Regular dot3 or synthetic or what?  However, I did not pump pedal after topping off. So l
 Siphoned the fluid out of the master cylinder. As soon as I am sure what fluid to use, I will
 Fill master cyl. I'm new to trucks, and I know sometime ago they went to synthetic fluid, just
 Don't know when.  Thanks.    Jerry
				Dot 3 is dot 3, dot 3/4, dot 5.1, are all a glycol based fluid. All have different heat ratings and boiling points.
 What you do NOT want to do is mix synthetic (3, 3/4, 5.1) with silicone based fluid (DOT 5).
 DOT 5.1 and DOT 5 are NOT compatible, even though the numbers are similiar.
 And as an FYI, DOT 5 cannot be used with ABS equipped trucks, the rapid pulsing of the pistons can actually make the fluid "froth" and may create air in the system.
 Sent from my SM-S920L using Tapatalk
				Thanks 67 kaiser
				People tend to think brake fluid is eternal. If it has never been flushed, now would be a good time.
				So, in the end what type of fluid did you use?! My dad's 87' Chevy is also having the same issue right now. Actually, he had a very bad brake fluid leak a couple of months ago, and I think that he should really change to whole brake system, as it is not the first time when he is facing this kind of issues. He has tried a lot of brake fluids however he does not know which one is the best. After reading an interesting article on cararac (https://cararac.com/brake_oil/), I told him that the dot3 is the best one, however he does not agree with me.
