73-87 Chevy _ GMC Trucks => Electrical => Topic started by: Mike Phillips on September 04, 2017, 09:46:50 am
Title: Windows quit working after re-installing air conditioning duct under dash - 1987 Silverado
Post by: Mike Phillips on September 04, 2017, 09:46:50 am
Here's a picture to give you an idea of what I'm talking about.
(https://uploads.tapatalk-cdn.com/20170904/140395613a2a81cb711139ae5ab10257.jpg)
I didn't see a fuse for electric windows?
(https://uploads.tapatalk-cdn.com/20170904/d6e2d2c8d9fee17e92c83298e120ba8b.jpg)
Is there something under the dash I could have damaged or loosened when putting that plastic air conditioning duct back into place?
Both windows worked before, now neither work.
Truck is at the shop, will be taking a look under the dash tomorrow - thought I'd check with you guys first.
Title: Re: Windows quit working after re-installing air conditioning duct under dash - 1987 Silverado
Post by: VileZambonie on September 04, 2017, 05:40:02 pm
Check the ground connections above the parking brake mechanism. Check the pink wire and make sure it's plugged into the fuse block. Check to ensure you didn't disconnect the connector for the drivers side pw/pl harness.
Post by: Mike Phillips on September 05, 2017, 06:50:09 am
Thanks!
Will check today.
Post by: bd on September 05, 2017, 01:10:31 pm
Mike, on a side note, is there any particular reason your fuse capacities are mismatched to the fuse box?  Bear in mind that oversizing a fuse can damage the connected wiring and result in an electrical fire.
Post by: Mike Phillips on September 06, 2017, 10:29:37 am
So far can't see anything not connected.  Might have to remove the air conditioning duct to fully inspect.
Hurricane on the way, need to get the window up.  If we get hit and get flooded I'll have one of the few trucks on the road that can drive through high water.
Post by: Mike Phillips on September 06, 2017, 10:31:54 am
I'm sad to say I bought this truck, didn't build it which I prefer.
Whatever fuses are in the fuse block were there when I bought it and I never paid attention until I took the picture you see posted in this thread.  Everything works, or at least everything did work until I replaced the master cylinder and power brake booster.  Part of replacing these items was removing the air conditioning ductwork and after re-installing it now the windows don't work.
I have time this Thursday after work to tear into it again...
Post by: VileZambonie on September 06, 2017, 10:51:20 am
There is a grounding bus above the parking brake mech, make sure you check it. Good luck with the storm.
Post by: Mike Phillips on September 06, 2017, 12:12:41 pm
Yes, I saw that.  Hard to contort the human body in a way to look up under the dash.  Will double check tomorrow night.  I have a car detailing project tonight that starts at 5:00pm and goes to around 9:00pm.
Post by: Mike Phillips on September 06, 2017, 06:09:09 pm
Air cond duct is out
(https://uploads.tapatalk-cdn.com/20170906/de642bbc3805d45d9b475d26b7b0d067.jpg)
Post by: blazer74 on September 06, 2017, 07:25:25 pm
Without looking at a diagram Is there not a circuit breaker in the window circuit?
Post by: Mike Phillips on September 06, 2017, 09:01:32 pm
Fixed.
It was a loose wire.
Winders are up!
Post by: VileZambonie on September 07, 2017, 06:32:01 am
Which wire?
Post by: Mike Phillips on September 07, 2017, 08:00:08 am
Which wire?
It was a white wire up under the dash.  I should have taken a picture but I was trying to get her fixed, put back together and call it a night.
If I ever take it apart again I'll take a picture for the forum.
