73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: tbarsell on September 23, 2017, 02:16:55 pm
Title: bed swap and fuel filler neck.
Post by: tbarsell on September 23, 2017, 02:16:55 pm
have a 77 c20 longbed 3/4 camper special with dual saddle tanks. truck got hit and ruined the bed. picked up a 73 bed to replace it.
My problem is the 73 bed has fuel doors while the 77 bed has the fuel filler neck and cap flush with the body panel. i am pretty sure that i will need to change out the fuel necks but am unsure where to find them. the   catalog doesnt show a fuel filler door option for the 73 bed. any help is appreciated.
thanks
Title: Re: bed swap and fuel filler neck.
Post by: fitz on September 23, 2017, 02:41:05 pm
A bed from a 1973 should  not have a fuel door.
Post by: tbarsell on September 23, 2017, 03:19:27 pm
right. tail lights are 73. so i assumed....must be a 79 or up bed. just need to get the right fuel neck and what not to make it fit the 77
Post by: VileZambonie on September 23, 2017, 05:34:14 pm
73-77 had the round hole so if you bought a bed with the gas door, then get the appropriate hardware for a bed with the door.
Post by: 75gmck25 on September 28, 2017, 08:07:23 am
I swapped an '81 bed onto my '75, and had to get the fuel filler pipes and hoses from a newer bed with a fuel door.  Original tanks worked fine.
You can still buy the filler pipe parts new, but last time I checked they were much pricier than I expected.  It was much cheaper to get what I needed from the pick and pull.
Bruce
Post by: chevn-up on September 30, 2017, 05:22:31 am
Be careful if ya go to the salvage yards. The 78-87 fuel filler hoses are a different diameter than the 73-77.
Post by: Jason S on October 01, 2017, 03:16:27 pm
The link below has additional information on the fuel filler hoses.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=29219.msg245101#msg245101 (http://forum.73-87chevytrucks.com/smforum/index.php?topic=29219.msg245101#msg245101)
