73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Surfdude on September 28, 2017, 12:08:56 pm
I know there are lots with more experience than me and a few of you who also have to contend with the lovely CARB regulations here in California so..
1978 Chevy C10
Engine 350 SBC
Intake manifold with all of the state-mandated smog fittings casting number: 346249
The new block has a casting number of 10243880, 92-96 model years.
Will the two mate unmodified? I ask because as I am trying to put the manifold on but the 4 center bolts look as if they are drilled at a more perpendicular (straight up) angle than the rest. I am asking before I get the grinder out and modify the holes then epoxy back to size.
I would like to put an aftermarket intake manifold on, but there are no intake manifolds with the magic EO (executive order) paperwork available. Has anyone put on a Performer manifold with the EGR option and successfully passed smog in CA?
I want to keep it carb'ed (I luvs me the sound of 2ndaries opening up) so am leaning against TBI, that and the hassle of the state come smog time.
I appreciate all of the help, I would post pictures if I was doing anything interesting but all of us have seen greasy engines that have sat for 30+ years.
Thanks for the help,
It's not the block it's the cylinder heads that you have to worry about. If you are putting an early manifold on center bolt heads then you need to elongate the 4 center bolt holes. I'm fairly certain professional products intakes come with the adapters and elongated holes.
They do. I have one on an 87 350 in my 37
Thanks, I have not contacted Professional Products. Let's see if they have a CARB-certified intake manifold. ( I think this is a unicorn)
This is what I get for 'knowing' without verifying. I just knew the cutoff for smog was the model year when they went to TBI when I bought this. ::) Bah.
Well, Just have to get on with it. Worse case I will tap the existing holes in the manifold, fill with a low grade bolt, and re-drill at a more correct angle.
I think I can figure out something for a boss for the bolt side and braze it on afterwards.
If only I 'knew' (there is that word again) that IF I bought an aftermarket manifold with an EGR that all would be OK with the smog police. I personally don't see why not but I ran into a similar situation a few years back with a cracked intake manifold and the referee would not budge. OEM, junk it, or TBI were my options.
Again, thanks for the help here. If Professional Products doesn't have what I can use, I will post the ensuing photos for the collective hilarity and head-shaking of the general community.
Drilling out the 4 center bolt holes in the intake is a simple and easy solution. You can make angled bushings yourself as well.
Or buy them but it's easy enough to fab something up http://www.jegs.com/p/Professional-Products/Professional-Products-Intake-Manifold-Bushings/2849675/10002/-1
