73-87 Chevy _ GMC Trucks => Engine/Drivetrain => LT/LS Swaps => Topic started by: nighthawker5 on October 01, 2017, 01:22:10 pm
Title: LS starter solenoid
Post by: nighthawker5 on October 01, 2017, 01:22:10 pm
So I'm hooking up the starter and I torqued the nut on the starter switch wire and broke the stud.  I got the solenoid off but can't see if there's a way to get the stud out.  Any suggestions? I know these are cheap but I'm mad I torqued it too hard.
Thanks
Title: Re: LS starter solenoid
Post by: smurfasaur on January 09, 2018, 01:31:55 pm
Probably an easy out is going to be your best bet... but you might spend about as much on a new solenoid
Post by: smurfasaur on January 09, 2018, 01:32:18 pm
If you don’t already have the right size easy out or know someone who does at leazt
Post by: bd on January 09, 2018, 02:09:29 pm
The machine screw comes out from the back side of the plastic cap.  Don't try to repair the solenoid.  It isn't worth the trouble.  Either replace the complete starter or, if money is tight, just the solenoid.
