73-87 Chevy _ GMC Trucks => Interior & Equipment => Topic started by: Madmick on October 12, 2017, 11:20:38 am
Title: New member. Need some help
Post by: Madmick on October 12, 2017, 11:20:38 am
Hey guys. Just joined today. my names Mike. Been long over due since I've had my truck awhile. It's a 1980 c10 diesel Cheyenne that was converted to four wheel. Also changed the engine the to a 350 and a th350 trans. Regardless I'm happy to be on here and apart of the family.
Reason I'm posting I need some helping identifying two things
First is that black box after tracing the wires and seeing I have a four prong brake switch. I gathered it's a cruise control module but I want to be sure and if it is can it be replaced.  The truck doesn't have cruise control I assuming the previous owner did away with it on the column but left everything else.
Second. the plug. It's hanging under the dash behind the radio. In that general area.
Title: Re: New member. Need some help
Post by: bd on October 12, 2017, 12:24:59 pm
Welcome to the forum.
The 'black box' is the diesel engine control module for the glow plug relay, fast idle control and warning lamp.  Use the 1980 Wiring Manual (http://www.73-87chevytrucks.com/techinfo/7387CKMans//Wiring/ST_352_80_1980_Chevrolet_Light_Truck_Wiring_CK_10_30_Only.pdf) as a guide if you want to remove wiring.  The disconnected  plug is the power/ground/display light connector for the factory radio.
Post by: Madmick on October 12, 2017, 05:02:24 pm
Hey I wasn't even close but but thank you for straightening it out for me
Post by: VileZambonie on October 12, 2017, 05:29:28 pm
You know what bd stands for....
Post by: bd on October 12, 2017, 10:00:52 pm
HAHaha!  I've got a few aliases.  But, that's not one of them.   ;D
Post by: VileZambonie on October 13, 2017, 05:34:20 am
 ;D
