				i'm doing this swap, i already have the 700r4, tv cable, adapter, and my driveshaft is getting shortened. the frame also already has the holes to move the crossmember back. what i need to know, is it has an electric kickdown and it needs constant power...can i get this plug from the dealership? and will the speedo gear from the 350 work, or will i need a new one?
				shaved,  you going to need the speedo gears for the 700r4, th350 are different, may have to lengthen speedo cable too.  if your 350 is a lockup converter, then you already have the plug there,  if not you will need to get a lock up kit so you dont burn up the trans.  I'm also assuming you have a short shaft th350? if it is a long shaft no need to cut driveshaft.  dont forget to plug off the old modulatior vacuum line too.
check this sight out,  these people are very helpful and they have the gear charts ,
www.hotrodlane.cc
www.transmissioncenter.net
goodluck with the swap,
  steve
				Might want to look at this for the lockup also:
www.73-87.com/7387garage/...lockup.htm
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
				the shop that rebuilt the trans installed a lockup, but it has a 4 pin connecter, will it work?
