hey all, my truck runs really rich. which way do i turn the screws to lean it up? i tried setting it the way i read in the forums earlier, but when i disconnect the advance, it just dies. and regardless of how much i turn it, it stays roughly the same. by tightening it clockwise, i notice once i got far enough, it got rougher and lower idle, but other than that it doesn't really change. but i can defenitely smell gas in the exhaust, and so can everyone else. its a rochester Qjet 4 barrel. thanks for the help!
someone please help. turn clockwise to lean or counter? it seems i can take off the vacuum advance without it stalling now, so thats good. but i still need help! thanks
Turning the screws in (clockwise) leans it out, turning them out richens it up.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
thanks, thats all i needed to know....for now
The guys at www.badasscars.com have a pretty good tips area, they give a pretty detailed answer here, and some common mistake explanations.
This is an easy one. Some people think you're supposed to turn them all the way in, and then back them out 2 1/2 turns. That would be great if it was that easy. The fact of the matter is, the idle mixture screws are directly affected by the engine's displacement, the cam profile, idle vacuum, timing, etc., and being that pretty much any carb can be put on any engine, how could a "standard" 2 1/2 turns adjustment possibly work? It can't. You can't put a 750 carb on a 302, and then the same identical carb on a 502 cubic inch engine and expect to have the same idle bleed settings. Here's how you adjust them. Start the engine and let it warm up. Set the idle screw so that the engine is idling at a normal RPM. Take a small screwdriver and start turning one bleeder screw on one side of the carb inward until the idle either drops or rises. If it drops, you are going the wrong way, so turn it the other way until the you hear the engine's idle rise back up again. If it raises, keep turning it SLOWLY until it peaks-out and starts to drop again. So what you want to do is adjust the screw until you get the highest idle. Then go back and re-adjust the actual idle speed screw to re-adjust the idle back down to the normal RPM again, and repeat what you just did to the other side of the carb. When you are done with that side, and you have found the highest possible idle, go back again and re-adjust the idle screw so the engine is idling back where it should be. Keep in mind, these are IDLE bleeds only. In other words, the second you crack-open your throttle, these idle bleeds quit working. Some people think they can lean out or richen a carb by simply adjusting these screws, and that is SO wrong. The only thing you are adjusting is with these bleed screws is the IDLE mixture. The ONLY way you can lean-out or richen-up a carb from the outside is if you have a customized carb with a "Dial-a-Jet" system, on it, otherwise you have to open-up the carb and swap the main jets out to either a larger or smaller size.
Do you disconnect the vacuum advance line when adjusting the idle mixture?
