73-87 Chevy _ GMC Trucks => Performance => Topic started by: Chuck Step-a-side on April 08, 2018, 12:31:17 pm
Title: 1984 Chevy Silverado Stepside w/350 trans
Post by: Chuck Step-a-side on April 08, 2018, 12:31:17 pm
I have a banged up driveshaft and will need to either replace it or have the driveshaft repaired and balanced. What other year and model chevy truck have a 57" tube length driveshaft that will fit my short bed? Thanks
Title: Re: 1984 Chevy Silverado Stepside w/350 trans
Post by: Irish_Alley on April 25, 2018, 02:08:47 am
one out of a truck with the same trans/axle
Post by: 75gmck25 on May 01, 2018, 07:14:59 am
Where are you located?
When I lived in San Antonio I had a local place called Driveshaft Specialists make me a new front driveshaft for my K25, and it was a very common job for them.  It cost more than a junkyard pull, but everything was new (cardan joint, etc.) and it was an exact fit.  I believe they also repair, balance and shorten driveshafts.
Bruce
Post by: Irish_Alley on May 02, 2018, 07:13:42 am
just to add to what bruce said, its a good idea to rebuild the front driveshaft anyway. by time you get the needle bearings and u joints it will add $50-$70 (about $30 for the cardan joint rebuild and $10-$20 for u joints) to what a junk yard shaft will cost plus the splines on the shaft might be worn anyway
