73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Brakes and Braking Systems => Topic started by: Ronno6 on June 26, 2018, 12:14:47 pm
Title: JB3 to JB5 rear brake upgrade
Post by: Ronno6 on June 26, 2018, 12:14:47 pm
Should I not be able to resolve the imbalance of my mixed-component braking system (JB5 front; JB3 rear)
the options are:
1.Convert the front discs  back to the original JB3 set up, or
1.Convert the rears to the JB5 option.
I would really like to upgrade the rear if possible.
For the first, would new rotors and calipers be all that is required?? Are wheel bearings and pads the same?
For option 2, would drums,shoes and cylinders do the trick? Would the larger diameter shoes make the drums too large
for the backing plates? Would the wider shoes make the drums too wide to fit without having to have longer axles??
Would the 3/4" wider shoes require a top pivot change?
I really hate having to fix a previous owner's mixing of parts..
Title: Re: JB3 to JB5 rear brake upgrade
Post by: Ronno6 on June 26, 2018, 02:27:59 pm
I have seen where a member called  bd  has done this.
Whacha say, bd ??
Post by: zieg85 on June 26, 2018, 03:59:40 pm
I can tell you the calipers from the larger rotor won't fit on the smaller spindle...  For the hassle on the rear consider going to a disc brake set up.
Post by: Ronno6 on June 26, 2018, 04:58:38 pm
The rotor is only thicker...not larger in diameter.
Are yoiu saying my spindle is not the came one as for the JB3 setup?
I have thought about going discs on the rear, but it is pretty expensive..........
Post by: zieg85 on June 26, 2018, 11:17:36 pm
What I am saying is the calipers are different and won't go on the JB3 spindles.  I had a bad caliper and my parts truck had the thicker rotors and I tried using the JB5 caliper and it wouldn't work
Post by: Rattler12 on June 27, 2018, 08:12:40 am
Also the backing plates are different for JD5 vs JB3...……..    and good luck finding them for JD5
Post by: Ronno6 on June 27, 2018, 10:45:39 am
Ain't that the truth!
Post by: bd on June 27, 2018, 12:16:49 pm
Read through JB3 to JB5 Upgrade (http://forum.73-87chevytrucks.com/smforum/index.php?topic=33916.msg288722#msg288722).  The part numbers provided also apply to the 1984 model C trucks.
JB3 and JB5 front disc brake parts are not interchangeable.  Although the pads are the same, there are physical differences in the calipers, rotors, hubs, spindles, bearings, seals, dust shields and possibly the hoses.
JB3 and JB5 use the same master cylinder.  The JB3 and JB5 brake caliper piston bores are similar diameters and use the same friction pads.  However, JB3 uses a single diaphragm vacuum booster while JB5 uses a dual diaphragm vacuum booster.  The dual diaphragm booster provides greater pedal pressure delivery to the master cylinder for decreased pedal effort.  JB3 and JB5 brake options incorporate different combination valves (although I doubt you would notice any difference in performance by using a JB3 valve with JB5 rear brakes).
My 1987 R10 uses 1-3/16" bore (JB8 - 1 ton dually) rear wheel cylinders with JB5 rear drum brakes (11.15" x 2.75") and JB3 front disc brakes through a JB3 combination valve actuated by a dual diaphragm booster and JB3/JB5 master cylinder.  Pedal “feel” is normal and firm.  The vehicle stops on a dime w/o the rear locking up, unless I depress the brake pedal sufficiently to lock up all four wheels.
To find the non-consumable infrastructure you may need to scour the yards unless you are fortunate enough to find NOS.
Post by: Ronno6 on June 27, 2018, 12:46:24 pm
I had stumbled on to that thread before. Good information!
I just cannot understand why I cannot get my rear brakes to quit locking up under normal braking loads.
I have tried about everything I can think of and replaced about everything but the hoses.
I have observed them under vacuum assisted pressure and can see no elongation or swelling.
I think I am going to try the 15/16" bore rear cylinders in an effort to reduce the rear braking.
Those are the ones specified by all the parts houses for the JB5 rear brakes.
I have found JB5 backing plates for a 1987 C10, but am having a difficult time verifying that they will work on my 84.
The various websites for the plates you have spec'd list model years all over the map for various vehicles, but seldom list
either 84 or 87 C10's
Anyone know for sure if they are interchangeable for those years?
Post by: Rattler12 on June 27, 2018, 02:34:32 pm
You might try an adjustable prop valve in your line to your back brakes
Post by: Ronno6 on June 27, 2018, 03:40:59 pm
That may be a good solution.
For the time being I am gonna try the 15/16" bore wheel cylinders.
The least expensive of all fixes.
Should reduce rear brake pressure by 14% and reduce pedal travel.
Post by: Ronno6 on June 28, 2018, 02:40:47 pm
I have found, on page 861 of the parts guide Cat 52A
https://www.mediafire.com/folder/1zf0zcabliv77/Parts_Books
ALL have 1.28" thick rotors.................
WHAT'S UP WITH THAT ?????
Post by: bd on June 28, 2018, 03:37:13 pm
You have a 1984 C10.  JB1 and JB3 use ~1" thick rotors.  JB5 and JD5 use 1.28" thick rotors.  Both the 1" and 1.28" thick rotors are 11.86" diameter.
Post by: Ronno6 on June 28, 2018, 03:47:39 pm
I believe that.
Interesting that the parts manual indicates differently:
To determine the correct brake system the following information must be known.
1. Gross Vehicle Weight (GVW). This is given on the identification tag located on the driver side door pillar or on Step Vans attached to the inside face of the dash and toe panel.
2. Model Number.
3. H.D. Power Brakes (RPO JSS). This is an option available on most vehicles. When trucks are equipped with this option, the brake system may be upgraded to the next higher rating. (Example from JB3 to JBS) Trucks equipped with this option can be identified by checking the Service Parts Identification Sticker. '
EXAMPLE:
If the truck had a CIO and 5400 GVW, it would be equipped with JB3 brake system. If the truck was equipped with J55 H.D. Brakes it would have the JB5 brake system.
1979-81 LIGHT TRUCK BRAKE SYSTEMS
RPO # ROTOR REAR DRUM/ROTOR POWER BOOSTER
JB1 11.88* x 1.28* 11* x 2.00’ None
JB3 11.86* x 1.28* 11 * x 2.00* 9.5* Single Diaphragm
JBS 11.88* x 1.28* 11.15* x 2.75* 9.5' x 8* Diameter Tandem Diaphragm
JB6 12.5* x 1.28" 11.15* x 2.75* 9.5' x 8 ' Diameter Tandem Diaphragm
JB7 12.5* x 1.28* 13* x 2.50* 9.5' x 8* Diameter Tandem Diaphragm
JB8 12.5* x 1.53* 1 3 'x 3.50* Hydro-Boost
JB9 14.25* x 1.53' 15* x 4,00* Hydro-Boost
JF-9 14.25* x 1.53* 13.75* x 1.53’ Hydro-Boost
JD3 11.86* x 1.28* 11' x 2.00' Hydro-Boost
JDS 11.86* x 1.28* 11.15* x 2.75' Hydro-Boost
JD6 12.5* x 1.28* 11.15' x 2.75’ Hydro-Boost
JD7 12.5* x 1.28* 13* x 2.50* Hydro-B
Post by: bd on June 28, 2018, 07:16:44 pm
There is a lot of conflicting information floating around the web.  One thing I'm not certain of is whether there were production changes that affected rotor specifications through the years.  Meaning, truck weights decreased moving forward in time and the weight had to be trimmed from somewhere.  Glass and sheet metal were thinned, frames were thinned, etc....  Decreasing truck mass may have allowed for lightening certain brake components as well(?).
Our "in-house" reference is Brake Tech, what do all the numbers mean.. (http://forum.73-87chevytrucks.com/smforum/index.php?topic=28592.msg238566#msg238566)
Post by: Ronno6 on June 29, 2018, 09:03:54 am
Is there a way to tell the difference between a JB3 single diaphragm booster and a JB5 double diaphragm unit??
Post by: Henry on June 29, 2018, 01:14:26 pm
Hi Ronno6:
I am pretty sure they will have different diameters of the diaphragm shell...sorry I am not familiar enough with them to tell you what the diameters are...I think the dual diaphragm is going to be smaller. You can probably do an internet search where they are documented. For my 76 truck all the vacuum power booster units were supplied by Delco Moraine or Bendix. Both companies made single and dual diaphragm.
Regards,
Henry
Post by: bd on June 29, 2018, 06:29:14 pm
The single diaphragm booster is like one wafer of an Oreo cookie while the tandem booster is like a double stuffed Oreo.   8)
Post by: Ronno6 on June 30, 2018, 03:48:42 pm
If the pictures I see on the web are indicative, I already have the JB5 double diaphragm booster.
One less thing to buy and change out................ :)
Post by: Ronno6 on July 06, 2018, 06:37:58 am
I have purchased a pair of "loaded" backing plates for JB5 setup.
I'll completely rebuild them and get a set of drums.
When I install the posi and regear, the new setup will be installed as well.
Post by: bd on July 06, 2018, 10:16:02 am
I think you will be pleased with the outcome.
Post by: Ronno6 on July 14, 2018, 02:29:12 pm
I just received my JB5 rear brake assemblies purchased on ebay.
They are splendid and complete, right down to the E-brake cables!
The shows appear to be new..no grooves or wear pattern discernible!
At a C-note for the pair delivered, I am pleased (Shipping was about $45.00...)
He has another set id anyone is interested.
