73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: tdmsurfguy on July 29, 2018, 02:39:12 pm
My 1987 suburban with a 350 turbo 400 transmission randomly dies at idle when I put it in the gear or reverse. Any thoughts?
Welcome to the site
Hi TDM:
Hard to say without more info...is your Sub carburetted?....what kind of carb do you have in it? Does it run fine other than the random dying? Is it hard to start when cold? What is the dying like?.... is it instantaneous or is there a slow sputtering and bucking till it quits? Does it start right up after dying? How long has this been happening?
Regards,
Henry
check for vacuum leaks including the throttle body base gasket.
