73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: Payton1979Silverado350 on November 07, 2018, 07:07:44 am
I have a 1979 K20 single cab(AC) and recently I’ve seen water dripping from right above the kik panels (https://uploads.tapatalk-cdn.com/20181107/722a7f152414151a4694c9dbc49c4feb.jpg)
I was wondering if anyone knew what I need to order or any suggestions on where the leak is coming from ?
the leak will be coming from either, door cab seal / windscreen seal / bulk head wiper cowl.
mine was from under wiper cowl near heater fan.
remove glove box and kick panel. have someone with hose pipe spray water with you inside with a torch. you may have to remove dash top to see windscreen seal bottom.
Thank you
