73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Brakes and Braking Systems => Topic started by: relentlesshustler on May 06, 2019, 01:36:57 pm
I have a 1981 Chevrolet C30 car carrier with an LS 6.0L. The front brake line coming out of the master cylinder to the combination valve was replaced. Both front bleeder screws were stripped so both front calipers were replaced. LH front bleeds no problem, RH front won't bleed. I've pressed the "button" on the combination valve and tried to pull the fluid with a vacuum hand pump with no success. The rear bleeds fine. I'm assuming the master cylinder doesn't need to be bled because the LH front is getting fluid without a problem ? Any help would be greatly appreciated!
Remove the bleed screw from the RH caliper and check it to make sure it isn't obstructed. Then remove the master cylinder cap. Does any fluid ooze out of the open bleed screw hole in the caliper? It may take several seconds if the caliper is full of air....
Welcome
if you still get o fluid after what bd said try to remove the hose from the caliper and see if you get fluid to there. if still no fluid remove the hose from the hard line and see
