73-87 Chevy _ GMC Trucks => Fuel Systems and Drivability => Topic started by: gpday06 on August 10, 2006, 03:11:00 pm
what exactly do the fuel vapor canisters do? i believe that they just take the vapor concentrate it into a fuel and send it to the carb to be burnt, but im not sure, and since i have a 79 with dual tanks i dont have to worry about emissions, so could i just bypass them some how?
That's what it does, but the vapors don't concentrate into a liquid. The vapors are drawn into the carb or intake manifold (if tbi) by vacuum so they can be introduced into the burn cycle. Removing the cannisters isn't necessary, even tho a lot of us do it.. It helps clean the air by not allowing the unburned fuel to release into the atmosphere.
Don St.Clair
Culleoka Tn
Also helps to vent the tank.
thanks, thats what i needed to know
