73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: Cheyenne1010 on July 12, 2019, 01:05:37 pm
My name is Robert and I reside in southern California.I'm the owner of a 1973 C10 long bed,350 motor with a 350 turbo trans.so I've been buying new parts for my truck little by little.so the latest part I purchased is the rear window seal.i started to remove the old seal and of course I found rust,some areas are worse then other areas.there are more then a few spots where the metal is really soft,soft enough to push a screwdriver through.
My question is there a panel I can buy to replace those rotted-out sections or is there some kind of procedure to repair the damaged area.the sections that will need repairs I believe it's called a pinch weld,it's the bottom section of the rear window opening.any help with my problem will be very much appreciated.
Thank you fellow squarely truckers
Can you post some pics so we can see just what is going on?
Thanks!
