73-87 Chevy _ GMC Trucks => Interior & Equipment => Heating, Ventilation & Air Conditioning (HVAC) => Topic started by: josh0325 on October 15, 2019, 08:11:45 pm
Hey guys, I need a little help here. After installing previous engine I was. Breaking it in, and I had the starter wire too close to the headers. It caught fire and melted a lot of the wiring coming through the fire wall including wires for rear blower motor resistor. I didnt bother much with it, as I've only driven it this summer, and just kept the windows down. Now that it's cold I th ride the heat and defrost... and nothing is working. I ran a temporary jump from the dark blue wire by the blower directly to battery and it works...just on high only. Vacuum for hvac(which melted) I found in the cab and was able to get enough to push back through firewall, I connected to non ported vacuum on carb. Head unit does not switch back and forth at all between vent selectors. I've searched endlessly on the forums here and I am very much diagram illiterate. Can yall please point me in the right direction so I may have heat, and more importantly defrost. All fuses are good also.
