73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Catrik on December 10, 2019, 02:12:52 pm
1986 K10 with SM465, wondering what is the socket size for the reverse light switch? I don't have deep socket big enough and nothing else seems to fit there.
Sometimes is takes a second of two for my reverse lights to come on so I'm thinking there's some sludge build up in the switch.
Sounds like gunk in the trunk, i.e. corrosion in the sockets.
Just found a incredible product from FLITZ called Metal Pre-Clean. Eats crap off surfaces like I have never seen before!
It is acid based, so you can't leave it on any surface but I tell you what: I have spent countless hours scrubbing off crap when this stuff melts it off in seconds.
Flitz products seem to have fairly comprehensive applications...
https://www.youtube.com/watch?v=_KWxjShHl4E
Thanks.
To answer the original question mine is the original Pollak 2 blade style and it takes a 7/8" deep socket to remove it. there is a gasket around it that may not come with a new switch.
Thanks! I somehow missed your message earlier. I used a 23mm socket so 7/8" is probably the correct size. Turned out that a deep socket was too tall to fit in there with a ratched so I ended up having to make a custom socket from a cut off box end of a spanner, piece of pipe and a nut in the other end so I could turn it with another spanner.
I opened up the old switch and it was burned up from the contact points. If anyone else has this issue then you could try turning the plastic connector part just a few degrees so the contact points change. It might fix it, or it might snap off and now you have a broken AND oil leaking switch... ;D
Oh and good call with the gasket. I would have left mine sitting of top of the transmission if you didn't mention it.
I like it! Going old school............."if you don't have one, make one!!"
