73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: 73 SUPER 10 on October 04, 2006, 03:17:00 pm
Title: Electric fuel pump
Post by: 73 SUPER 10 on October 04, 2006, 03:17:00 pm
Hi guys, I have a 73 cheyenne with an electric fuel pump. It is wired to the ignition tang on the fuse box and runs whenever the switch is on. My question is : what is the safest and most reliable way to wire the pump? What parts will I need? Oh yeah the engine is a stock 454 with 350 trans behind it.
Title: Re: Electric fuel pump
Post by: roundedline on October 04, 2006, 02:33:00 pm
Sounds like it is hooked up the safest way if it is running off switched power. (although I am a little confused on the application..)
Why are you running a electric pump on a stock 454?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Post by: 73 SUPER 10 on October 04, 2006, 04:03:00 pm
That's the way it was when I bought it. Is it overkill and if it is how would it affect my engine. Thanks.
Post by: roundedline on October 05, 2006, 04:26:00 pm
Is it running a regulator on it?
The mechanical pump on the engine is more than enough to provide fuel to a street engine running a carb.  It only needs 5-7lbs of pressure for a Carb motor.
It isn't going to hurt anything if it is hooked up correctly though.
Project Su
Jimmy 2WD Project
