Technical Forum (Read Only) => Chassis Electrical and Ignition => Topic started by: bd on January 26, 2020, 07:11:16 pm
Title: Basic Skills: Soldering
Post by: bd on January 26, 2020, 07:11:16 pm
BASIC SKILLS:  SOLDERING
by bd
INTRODUCTION AND ORIENTATION
Well developed soldering skills are fundamental to every automotive electrician.  The best electricians routinely solder electrical joints to create high-quality connections that deliver exceptional performance over the long term.  Based in applied technology, soldering skills are quickly learned through fast-paced orientation followed by methodic on-the-job practice.  Preliminary steps include surface preparation, sturdy mechanical binding between two or more conductors, selecting the solder, flux and method of heating appropriate to the specific task, and determining precisely where and how to position the heat source to safely access the joint without exposing the surrounding environment to damage or imparting personal injury.  Although the preparatory steps can consume several minutes to organize and complete effectively, the subsequent process of actually heating and soldering the joint, and then withdrawing the heat source at the precise moment the solder melts to allow the joint to cool naturally and undisturbed, consumes only a few seconds.  With moderate practice, the entire routine progresses quite rapidly with excellent results.
The following article reflects my experience commercially repairing vehicles and, occasionally, consumer electronics.  My purpose is to convey a simple procedure that can be applied to good results by everybody while providing sufficient details to satisfy people who have insatiable curiosities.  Hopefully, my effort will answer more questions than it generates.
I organized the topic into three essential sections:  on page 1, a fast-paced orientation to establish a broad foundation; on page 2, a step-by-step description of the applied technique; and on page 3, desoldering techniques.
Screen Tip:  For optimal viewing, depress and hold down the "Control" key of your PC keyboard while rolling the wheel on the mouse to instantly resize screen resolution and accommodate the embedded images.
The Purpose of Solder:
Solder Selection:
About Flux:
Heat Sources:
Title: Basic Skills: Soldering Technique (page 2)
Post by: bd on January 26, 2020, 07:12:57 pm
SOLDERING TECHNIQUE
Preparation is a significant aspect of success and the dominant consumer of your productive time.  Rest assured that effort invested in methodic preparation will reap satisfying rewards when the job is completed and functioning as it should.  Although the following procedure emphasizes printed circuits (dominantly for the simplicity of illustration), there is little difference with regard to general wiring repairs.  The procedures are directly compatible and interchangeable.  To help minimize inhaling toxic vapors, take precautions to ensure the work area is open and well ventilated.  Always wear suitable eye protection!
Title: Basic Skills: Desoldering Techniques (Page 3)
Post by: bd on February 06, 2020, 10:27:20 pm
DESOLDERING TECHNIQUES
Now, for the seedy side of soldering skill: Desoldering!  The ability to take joints apart, cleanly and without damage, is as necessary a skill as putting them together.  It is inevitable that at some point you will encounter a soldered joint that needs to be disassembled to some degree, reconfigured, or completely undone and redone.  Such as it is, the process can be tedious depending on accessibility, the complexity of the joint, your level of experience, and your confidence in your abilities.
Disassembling a joint is notoriously more difficult than putting it together.  That’s just a fact.  There is little-to-no elegance involved.  Instances occur in which two or more methods must be combined for success.  As with soldering, an over-application of heat can impart disastrous consequences to thermally sensitive components.  Accordingly, conscious effort should be focused on minimizing prolonged component exposures to solder fusing temperatures (i.e., 361 °F (183 °C) or greater).
As always, safeguard your eyesight by wearing safety goggles!
Wicking Technique:
Suction Technique:
Low Pressure Forced Air Technique:
