73-87 Chevy _ GMC Trucks => Performance => Topic started by: bake315 on March 12, 2020, 01:01:13 am
So I pulled the 5.7 out of "Felix" ('87 R30) last week, and sent the block off to get bored (.030) and honed. I'm thinking I'd like to bump the cam up a little over stock, but given I'm sticking with the stock heads, intake and TBI with computer, I'm not at all sure what my options are - particularly with regard to the computer. I've been reading that there are some out there that are incompatible with what I have.
Anyway, I'd really appreciate any guidance y'all could offer on cam upgrade options. Thanks!
bake315
I've got eyes on this thread, have the same question.
I inherited a 383 stroked V8 out of a 86 Camaro. Drove the car prior to pulling- scary fast!
I can't find any information about the cam, maybe pay a shop to measure what it actually is performance wise.
Would anyone recommend I do the same for the heads, performance wise? Measure the volume?
In any event, it's going into the '80 C10 I've been doggin for a year.
To round out the spec's, 4bbl, analog ignition, TH350, daily driver.
Would anyone recommend a particular grind for this app? Thx! :)
What is your end goal? There are plenty of cam options for TBI engines but if you are keeping everything stock, a minimal bump is about all you should do.
Nothing too crazy, certainly not looking to make it into a race engine. I figured since I had to go in, might as well goose it a little, or as much as I can without having to go in and change a bunch of things I didn't set out to, you know? I'm just hoping someone could point me to a specific cam that would be something a little more than bone stock.
Thanks!
bake315
From what I gather, you have a TBI 5.7L .030" over R30 with stock intake and exhaust. If you aren't planning any other changes consider:
https://www.jegs.com/i/Edelbrock/350/3702/10002/-1
https://www.summitracing.com/parts/cca-12-388-4
https://www.summitracing.com/parts/sum-k1102
Stock cam lift for your engine is .2565"/.2690" (.385"/.404")
If you plan to ever make further upgrades down the road, factor that into your choices. Stock TBI heads are awful BTW
This is tremendously helpful information - thank you!
On the topic of heads, what would your thoughts be on these?
https://www.summitracing.com/parts/sum-162108?rrec=true
You could run a set of vortec heads and a vortec intake manifold with TBI adapter for about $700 bucks
It’s true that I could, and I had considered the Vortec option, but the fact is I’ve already spent a significant amount going in the conventional head direction, and really don’t want to have to reverse course from that now.
By the way, I was watching a YouTube video last night about GM-produced heads, and literally burst out laughing when he got to my stock heads, and proceeded to talk about how extraordinarily bad they were - like the absolute worst of the worst. Definitely echoed your opinion, for sure!
But matters of cost aside, is there any reason the heads I mentioned wouldn’t work well for me?
So I took the cam into a local cam shop, Schneider, if anyone has heard of them.
Been grinding since 1959.
They said it had low miles, then tested it and the specs say it's a 1970 350 350HP grind. "great cam' was his expression.
Said it won't pass smog, but even in Cali, the limits are ridiculously high.
They recommended a milder grind. Won't go beyond 5000 rpm, but will be snappy off the line.
I'm good with that.
i'm thinking of changing cams in the 4.3 and i'm hearing that for TBI, going one or two steps above stock, not TOO far from stock is ok. i don't run TBI, but i'm watching alot of videos and that's what i'm hearing about tbi.
Like if stock is 184/194 @ .050 , then 205/207 @ .050 would be ok. But then you wouldn't gain much.....?
Well, after thinking about it, I called the 'grinder and asked if there was enough material to do an RV grind?
On a 454 that I was forced to rebuild, I opted for a RV grind- I pulled a 5th wheel toy house full of stuff.
Between 2500-3500 RPM it was like I was towing Nothing!
So on this project, I opted for a RV grind. It will be snappy off the line, but won't be the gas suck of a Corvette.
