73-87 Chevy _ GMC Trucks => Interior & Equipment => Heating, Ventilation & Air Conditioning (HVAC) => Topic started by: batcomm1 on September 09, 2021, 09:42:08 am
Title: Heater & A/C blower doesn't work on high speed
Post by: batcomm1 on September 09, 2021, 09:42:08 am
I'm having an issue with no high speed but all other speeds work fine, is there a location for a high speed fuse only to check?
Sent from my SM-G991U using Tapatalk
Title: Re: Heater & A/C blower doesn't work on high speed
Post by: bd on September 09, 2021, 02:39:26 pm
What year/model truck?  Does it have an inline fuse connected to the firewall junction block stud?
Post by: batcomm1 on September 09, 2021, 03:27:36 pm
84 Silverado
Post by: batcomm1 on September 09, 2021, 03:29:31 pm
84 Silverado
Has all speeds but high, ran a 12v directly to it, got nothing, but as I said still works on all speeds but high...(https://uploads.tapatalk-cdn.com/20210909/cc3e2aae006e874f278ca067b1b12036.jpg)
Post by: batcomm1 on September 09, 2021, 03:30:52 pm
Here ya go(https://uploads.tapatalk-cdn.com/20210909/c1f636c3567b3eb2ac7dc6c0892c7827.jpg)
Post by: bd on September 09, 2021, 03:45:44 pm
Has all speeds but high, ran 12v directly to it, got nothing, but as I said still works on all speeds but high...
You ran 12v directly to what?  The blower motor?
Post by: batcomm1 on September 09, 2021, 04:24:54 pm
Correct, was a test with the switch on ....was advised to try it and was told the blower would come on high if it was good
Post by: bd on September 09, 2021, 05:21:51 pm
If the blower motor runs at low and medium speeds, the motor works.  Does the blower relay "click" when you select high blower?  Do you have a test light?
Post by: batcomm1 on September 09, 2021, 05:59:54 pm
Do have test lights and meters. I'll have to check for the relay "click"
Post by: bd on September 09, 2021, 07:25:15 pm
Use an incandescent test light and probe for I+ on the orange wire (Ckt 52 in the diagram, below) at the blower relay with the blower switch set to high, mode switch set to AC, and ignition switched ON.
Post by: batcomm1 on September 10, 2021, 07:58:30 am
Have light/12v on the orange in those listed conditions
Post by: bd on September 10, 2021, 11:02:54 am
Did the relay "click?"
Post by: batcomm1 on September 10, 2021, 11:24:27 am
Might be a dumb question but...am I testing these with the relay plugged in or just on the plug end off the relay
Post by: bd on September 10, 2021, 11:34:02 am
Wires must be connected to the relay but the relay can be unbolted from the evaporator housing if that makes for easier access.
Post by: batcomm1 on September 10, 2021, 11:43:42 am
So...I've only got power on the right side (battery side) of this...I'm assuming it has an internal fuse? If I jumper it across all works perfectly!!!(https://uploads.tapatalk-cdn.com/20210910/b11db83081812dbd55b67848976c0157.jpg)
Post by: batcomm1 on September 10, 2021, 11:57:36 am
Or is that strictly a "junction " and needs the posts "tied" together....
Post by: bd on September 10, 2021, 12:48:16 pm
Seems you found the problem.  There is no hidden internal connection between the two posts.  The posts should be bussed together with an unfused jumper and tied directly to B+ via a 12-gauge red wire connected to the starter solenoid 3/8" battery cable stud and a 6" long 16-gauge fusible link located at the solenoid end of the 12-gauge wire.  At this stage, you should trace and take inventory of the wires connected to the firewall junction block to determine whether someone has reconfigured and rerouted the factory wiring so that you do not inadvertently introduce wiring conflicts that might result in an electrical fire.
Post by: batcomm1 on September 10, 2021, 01:00:49 pm
Just did an LS swap into the truck so it's a good possibility that I did something...been a long process... I wantbto thank you for all you help and patience with me and my questions, now I get to start the process of integrating the 2007 ac compressor on the LS to the stock stuff on the 84 Silverado...load of fun for sure!
Again, thankbyou for all your help!
Post by: batcomm1 on September 10, 2021, 03:21:41 pm
I was told I needed to install a high pressure switch inline on the high presser side also, gotta try and figure that one out also
Post by: bd on September 10, 2021, 03:33:20 pm
There should be multiple options to accomplish that task, including custom hoses.  Good luck!
Post by: batcomm1 on September 10, 2021, 03:37:51 pm
Yup that's what I'm reading on now!
