73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Brakes and Braking Systems => Topic started by: 86LG4T5 on October 25, 2021, 05:10:22 pm
Title: C30 Wheel Cylinder
Post by: 86LG4T5 on October 25, 2021, 05:10:22 pm
I need to replace the wheel cylinder inside the drum brake.  I have it torn down to the backing plate.  I can't get at where the brake line connects behind the backing plate because of the huge leaf spring in the way.  Is there a trick?  Thank you!!
Title: Re: C30 Wheel Cylinder
Post by: 86LG4T5 on October 25, 2021, 06:01:30 pm
I ended up taking out the bolts that hold on the backing plate and pulled it forward to give me room.
Post by: VileZambonie on October 25, 2021, 06:03:04 pm
Crack the line loose, unbolt it, slide it forward, hold onto the line with a flare nut wrench and spin it off.
