		73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: Swampyankee74 on August 04, 2022, 02:04:43 pm
				I recently purchased a 1987 V20. While working on it I noticed the rear leaf springs had 4+1 leafs. The vin number says its a v20, the breaks and drive train all match a v20. Did someone swap the rear leaf springs out with a half ton pickup?
				I've got a good 1.38 million things going on, but I'll try to peek at mine tonight...
				Sounds good, thank you
				My 1980 C10 had twice the amount of leaves of my K20. You have to figure out what you want in terms of height and spring rate.
				The truck is stock height. No lift. And I intend to keep it stock. I just didn't know if somebody had taken the stock Springs out of it and put these in for a smoother ride.. Because like you said my 1974 C15 has doubled the amount of leaves as the v20. Made me think somebody might have altered it at 1 point in time. But you're saying you think that is the stock amount of leafs?
				My 87 V20 has 7 + 1!  No wonder it rides like a giggered tank....
				That sounds to me like the right number of leafs. Which makes me beleave someone at some point swapped these springs out with a 1/2 ton. The rest of the truck including Vin matches  what a v20 is supposed to be. Thank you for taking a peek at yours for me shifty!
				Just took a peek at my 74 c15 it is a short bed stepside and it has 7+1. It is bone stock unmolested.  But was ordered with heavy duty springs and clutch. Doesn't make sense to me the 3/4 ton has less leafs.
				I guess if your v20 has 7 leafs, and my half ton has more springs someone swapped the leafsprings out with a lighter truck.  I got porked. Lesson learned
				My 87 has 56" 7+1 on the Back and 4+1 on the front.
				Unless your SPID label is in place and shows the suspension options you are solely basing what it came equipped with on assumptions.
				That is true. I'll take a peek at it
				Just decoded the rpo codes on the spid. The truck is a 6600 pund gvrw. A lot lower then I would have expected.
