73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: benracing123 on January 27, 2023, 11:14:51 am
I installed a 4 barrel carb spacer trying to boost my cfms a drop, however now my transmission shifts at 3k rpm under partial throttle, anyone have any idea h I could be
I am going to assume you have a 700R4 transmission. You changed the geometry of the TV Cable. That needs re-adjusted.
It is
I don’t exactly know what the tv cable is but I’ll find it
I only have 1 cable to my carb linkage and it’s my throttle
(https://uploads.tapatalk-cdn.com/20230127/71df149025db49a0c2340a230cc37440.jpg)
Isn’t there supposed to be another cable next to the return springs?
Show us a picture of what transmission you have. If there's no cable it's a TH400
There should be a button to press behind the metal bracket on that black cable on top. You’ll have to test drive it once you adjust it and make adjustments as necessary so it doesn’t throw through all gears immediately.
This ^^^^.
Also, when you installed the spacer, did you unplug any vacuum lines and neglect to reconnect them?
I'm more interested in the spacer ;)
What's the theory?
What's the theory?
50 horsepower man. Now put magnets on your fuel line for another 10-20 mpg!
What's the theory?
And stickers....don't forget stickers....
Hey Ben, I think we've been diss'd hard :(
