73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Rear Drivelines, Drive Axles and Gearing => Topic started by: Swampyankee74 on February 25, 2023, 09:57:32 am
I have a 74 c1500 which originally came with a 250 6cl. I now have a 465 horse small block with a m21 tranny. Is the stock driveshaft going to be able to handle that with occasional abuse? Or turn into a twizzler?
LOL Red twizzler
Pry a bd question.
Didn't you say you were lowering it? If so what method did you use to lower the rear? Check your operating angles, make sure appropriate clearance, slip and good u-joints. Download the angle meter app on your phone.
I did lower it 4 inches in the back by spring hanger and shackle method. I'll make sure all clearances, and that the slip yoke isnot to far into the tranny, and new u joints. Just checking to see if that old tube could take the beating.
