73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Rear Drivelines, Drive Axles and Gearing => Topic started by: Snag on May 09, 2023, 08:35:12 pm
I'll be doing a swap from 2.73's to 3.42's on my truck and have a couple of questions . First off , I need to find pinion depth , I have a couple of ideas on how to measure from ring carrier center line ... These ideas involve machining (I have a quite complete home machine shop) a shaft with a flat spot and discs at both ends to center it in the bearing cups . Is there a tool I can copy or am I on my own for design ? Another question is how to lock down the pinion shaft when checking gear lash ? I'll be using a spacer sleeve and shims instead of the crush sleeve so that part is fairly easy . I have most of the tooling needed , what I don't have I can make in the shop ... but for some of these things I need a sample to copy . Right now I'm wishing it was as simple as when Dad re-geared the '59 Merc ... Unbolt one chunk and bolt in the other , slap the axles back in and roll .
I watched several videos on YouTube and decided even though mechanically I could do it and it would be a good excuse to buy some specialty tools needed, I would pay someone who has done it before
There are multiple ways you can find the centerline and measure depth. If you have the ability to make your own tooling it should be pretty simple. 10 bolt?
