73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: knuddy on March 02, 2007, 08:25:00 pm
hi,85 c10 350/350 and have swapped 350 for 700r4 and want to know what you guys are doing with the shifter lever on the side of the trans. i have taken the lever of the 350 and swapped to the 700r4 but when checking the operation of the shifter in the cab,i find i am not getting full movement at the trans.its like the ratio at the trans is different to the shifter ratio,is there a lever you can buy or do you have to fabricate something.my cab is right hand drive(new zealand)and uses a single cable from shifter to trans.can anyone help.
cheers
you might have to look for a conversion kit. If you can't find help here, ask the guys at shiftworks.com. Hope it helps.www.shiftworks.com/
Don St.Clair
Culleoka Tn
