73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: LILT77 on June 20, 2023, 09:16:10 pm
Title: Idler Arm and Pitman Arm Torque Specs
Post by: LILT77 on June 20, 2023, 09:16:10 pm
Looked through the FSM, maybe Im blind. Replacing the idler arm and pitman arm. Does anyone know the torque values associated with these parts? Idler arm to frame mount/center-link, pitman arm to gearbox/center-link?
Title: Re: Idler Arm and Pitman Arm Torque Specs
Post by: JohnnyPopper on June 21, 2023, 11:45:27 am
Mostly depends on the size of the bolt/nut/thread count. I'm sure there is a torque guide on line.
The ball joints of those components go as tight as you can to get the cotter pin to line up.
Post by: VileZambonie on June 22, 2023, 05:57:52 am
Pitman arm nut to gear box is 185 ft-lbs, pitman arm to relay rod is 66 ft-lb, idler arm to frame is 30 ft-lb, idler to relay rod is 66 ft-lb.
