Get a felpro one piece pan gasket...they are awesome. If you have a four bolt main, torque the outer bolts 60 ft lbs, inner bolts 65 ft lbs.
Definately go with a new pump...being the heart of the engine, they are cheap. Your labor will be done anyway since you have to remove your pump to replace rear main. Dont forget the gasket for the pump.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Edited by: SgtDel
at: 3/4/07 2:04 pm
I could've sworn mine came with one, but it has been a couple of years now. SgtDel
aka "Andy"
www.delbridge.net
